20 Most Recent
Minolta C250 Color Copier Questions & Answers
Screen doesn't turn on
Contrast turned up? start button orange? check the electrical plug at the rear of the machine snug and tight?
could have a bad control panel or the or the board that feed is bad. Recommended that you have a konicaminolta tech look at it. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Bizhub c6500 c2454
Black developing unit fault, has the black developer been replaced? Was it replaced correctly, with required counters cleared and proper test run after install? Was who ever installed new developer using a vacuum cleaner? If so might have destroyed the sensor located below the developer unit. (NEVER EVER USE A VACUUM CLEANER TO REMOVE DEVELOPER STATIC ELECTRICTY can destroy the ATDC (Automatic Toner Density Control) sensor. Toner mixes with the developer, on any Developer unit. So could have a bad sensor or control board. As for the counters if the developer was replaced but counters not properly cleared then copier thinks the developer is old and will adjust voltage as required when in fact new developer is installed and messing with image issues. KONICAMINOLTA PRODUCTION PRINT MACHINES USE THOSE COUNTERS!!!!!!!!! Btw, I’m available to help over the phone in case u need at
Multicolored not aliment
Do you mean that when you are print the colors are missed aligned. Or when you are scanning they are missed aligned? If the problem is scanning does it happen when the document is on the big glass? If when printing does the internal prints like the demo page do the same Btw, I’m available to help over the phone in case u need at
The prints have/Lines streaks in the image on all colors what needs to be replaced?
Enter in the service mode and tested in part every colors.Press Utility key - Meter count - Details - Stop 0 0 Stop 0 1 select test pattern gradation test select the colors and press Start key(the test is make A3 paper).If the test is OK verify the transfer belt unit and the transfer roller unit.If the lines appaire on the surface the transfer belt clean the belt cleaning blade and the cleaning brush used a vacuum cleaner.Clean used a special long tools under every image unit LED lines.
Black line across the top
Hi first do a cmyk test chart of each color if it happens when you do black copies then check the black imaging unit as it is not being cleaned and will give you black lines replace black drum unit
if it is on color copies black copies then the other thing to look at is the transfer belt unit and you may need to change the transfer belt
do the CMYK and you should get each color fully covered on each page see if there is any lines on the sheets in the same area you are getting the lines if so replace that color drum
Touch screen is not responding? Any options
Yes you will need to update the firm ware if this dose not fix the problem you will need to replace the control panel screen, if this dose not work you may have to replace the mfp board
Error code c5358, says to call technician
Power Supply Cooling Fan Motor/2's failure to turn The Fan Lock signal remains HIGH for a predetermined continuous period of time while the Motor remains stationary
I'm guessing you had the machine apart and forgot to plug one of the fans back in
Hi i have minolta Dialta 520 Photostate machine
The error code C-1028 on a Minolta Dialta 520 photostat machine typically indicates a problem with the paper feed system.
Based on your description, it seems that you have already replaced the PWB-B Board and checked all jacks, but the problem persists. In this case, there could be a few other potential causes of the error.
- Paper feed motor
- Main control board
- Gears or other parts in the paper feed system
- Paper feed sensor
Regarding the Bet Pin, it could be the name of a specific pin on the PWB-B board or in the paper feed system, but without more information about the specific location or context it is hard to say exactly what it is referring to.
It is recommended to consult the service manual of the machine, or contact the manufacturer or a professional technician for further assistance. They will be able to diagnose the issue and provide the necessary steps to fix it.
