20 Most Recent
Sony Ericsson K660i Cellular Phone Questions & Answers
Unlock kod k660i
Is that code is mistakenly typed as kod? If it is so then i will help you to get your Sony Ericsson.There are so many online providers available to unlock your mobile. Get the code from
Mobileunlocksolutions.com ,who is one among those online providers. I would suggest them to you for their reliability. You can unlock your mobile using unlocking instructions which is given in the site itself.
How to set time
It's easy to change time on your phone. Follow the instructions below.1.From standby code select Menu>Seetings>the General tab> Time & date >Time.2. Enter the time and select Save.If you have further doubts, read this online manual (
CLICK HERE ). It contains all the information regarding the operation of your phone.
K660i no power
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
I've sony k660i.the problem is
Seems to be a possible failrue on the mother board or harware. so to confirm if there is any errors in the software , try to reset, so remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is possible that there are problems in the main board/panel. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Qual o reset do sony ericsson k660i
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
UNLOCK CODE
To Unlock Your Sony Ericsson K660I from Network Lock use the Unlock code.Buy the Unlock code from the site
Wickedunlock.com and Unlock it easily.
