20 Most Recent
General Electric 28811FE2 Twin Cordless Phone Questions & Answers
Ge model 28811FE2-A does it have voicemail
The 28811 does NOT come with a voicemail system. The voicemail indicator will flash to indicate you have voicemail on your telephone company's voicemail system. This system will record messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.If you need manual, you may download a copy
here.
How do I use the room monitor? when I go to menu
Very Cool Feature. With the handset off, press the mute button(menu/ok). then arrow down to ROOM MONITOR. press the mute button again. it will prompt "ROOM MONITOR EXTENSION?" press either 1 or 2 depending on what handset you are using(if 1 doesn't work, try 2). And that is it you can really hear what is going on. To stop monitoring, press cancel.
Have Fun,
SKA
Retriving my voice mail
Since voicemail is set up through your phone service provider, you should contact them to see what their access number is. If you don't want to try to remember the number, program it into speed dial.
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
How do I change the answering machine message?
CLICK HERE for a PDF version of your manual.
However, there is no indication of a answering machine on this unit.
Is the model # correct?
You posted for 28811FE2
Please verify the number and re-post if different. If you have voicemail through your telephone provider, your message is set through them, not on the phone.
Thank you for using FixYa - A FixYa rating is appreciated.
Why am I not receiving General Mailbox voicemails?
Please make sure that the customer is calling the correct number that you think that they're calling. Then, call this number yourself and leave a message before going to check the message again. If you can't find your message, please call the business' phone company and ask them if there are multiple mailboxes linked to your business phone number. If so, they can provide access to the other mailbox for you.
Thank you.
