20 Most Recent
Polycom VSX 6000 (220022222001) Video Conference Questions & Answers
Microphone not getting connected Changed interface
Try changing the wire. Must be the 30 foot cable not the 10 foot which is specifically the daisy chain ... The former 30 foot is the specific cable from codec to mic. If changing this fails and you tested the mic, then your unit is either suffering corrupted software or the mic hardware is damaged. David
3 way video conf
Your VSX 6000 does not support Multipoint. YOu will have to move up to the VSX 7000 or 8000. The VSX 7000 supports MP and the VSX 8000 supports 6 site mp if you have that option installed. DAVID
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
VSX 6000 - Time Server doesn't work
it is not able to resolve the IP address for the time server. I am having the same problem. If you enter in the IP address for the time server it will resolve your problem
VSX 6000 - Time Server down
I have such a problem: when I connect VSX 6000 to the Internet, it doesn't work. It is connected through the swith D-Link, total length of network cables is about 150 metres. Inside the diagnostik I see, that Time Server is red, i.e doesn't work. But IP Network lights green! IP adress is phisical, whithout proxy and firewalls.
I want to notice, that notebook, connected to the same LAN-port works whithout problems!
