20 Most Recent
DeLonghi Stiromeglio Compact PRO 300 Iron Questions & Answers
Heat element light comes on (so there is power) but the iron will not hear up
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
8/23/2014 1:52:18 PM •
DeLonghi...
Answered
on Aug 23, 2014
I am unable to stop the steam at the iron. The
I would first try with household vinegar (empty as much water as possible) and if that doesn't work to free the valve, then something more aggressive containing acid like any of the Lime Away type of lime/rust removers.
If it is still stuck, you may have to bet the iron hot to make the acid more effective.
If using other than vinegar, I wouldn't advise allowing anyone to breath the vapors; do this in a utility room or basement.
That trigger probably acts on a needle valve that controls the flow of water to the point at which it is turned to steam and it may simply be too contaminated with lime buildup to slip back into the valve body.
1/11/2010 1:55:21 AM •
DeLonghi...
Answered
on Jan 11, 2010
