20 Most Recent Leisure SPC-54 Patio Heater Questions & Answers
0answers
0answers
I do not understand my data plate on my Leisure Victoriana EL gas cooker.
find a dealer locally
8/13/2021 3:48:21 PM • Leisure Heating... • Answered on Aug 13, 2021
2answers
When the jacuzzy water heater is turned on passing a small electric shock to the water.
turn it off and call an accredited electrician before some gets electrocuted there is to be no small anything where power is concerned
9/7/2015 6:00:43 PM • Leisure Heating... • Answered on Sep 07, 2015
0answers
WE HAVE A FEDDERS AZ7A09W2A Through the Wall Room Air Conditioner. IT WILL NOT TURN OFF. PULLING THE POWER CORD IS THE ONLY WAY. DOES ANYONE KNOW THE CAUSE AND OR REPLACEMENT PART?
Question edited for clarity, full 'make model (what it is)'. Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks! Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Repair Clinic has some good ideas, but your model is discontinued
Fedders Air conditioner won't turn off
Repair Clinic https://www.repairclinic.com > RepairHelp > Fedders-Ai... Here are the most common reasons your Fedders AC compressor won't turn off - and the parts & instructions to fix the problem yourself.
Why Your Air Conditioner Isn't Shutting Off, and How to Fix It
Williams Comfort Air https://williamscomfortair.com > ac-wont-shut-off When your air conditioner won't shut off, it's natural to worry about wasting electrical power as temperatures become too cool for comfort. ..
4/23/2024 2:50:42 AM • Heating &... • Answered 5 hours ago
2answers
I have a Bonair evap aircon model VSL75 with the comfort controller and I want to reduce the water dumping cycle down. I have tried the manual but that sequence didn't work.
Here are the steps you might want to follow: Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping. Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off. If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
4/21/2024 11:19:53 PM • Heating &... • Answered Yesterday
What is E3 in frego split ac
Frego split ac error code h3 what is problem
4/16/2024 4:25:39 AM • Heating &... • Answered on Apr 16, 2024
2answers
What does E2 code mean on electric infrared heater
Model 2320cpb. E2 code
4/13/2024 11:00:34 AM • Heating &... • Answered on Apr 13, 2024
Leisure SPC-54 Patio Heater Logo
2 questions posted
Top Leisure Heating & Cooling Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Leisure Heating & Cooling
Most Popular Question
electric fireplace insert
  • Heating & Cooling
