20 Most Recent
Lasko Ceramic Heater Questions & Answers
Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Electricity cost per hour
1500w / 1000w = 1.5 kwh. Every hour you run (assuming it is at 100% peak power) you use 1.5 kw. Just multiply that rate by how much it your power company charges per kwh.
Estimating high at 10 cents per kwh it would be $1 for every 10 hours you run the heater, or $2.40 per day, or about $72 per month if you ran it 24/7 for 30 days.
It is FAR cheaper to use these types heaters to heat one small room than an entire apartment or house if you are only in one room the majority of the time.
Great device easy to use OK but the electric cord
As far as the cord being warm that is pretty normal as is the power consumption depending on the temp. setting. However I think that much of a increase is excessive so I think if it was me I would return it to walmart and try to get a replacement. It has been my experience with walmart that they generally are quite good at in store replacement within 90 days.That way you could have a basis for comparison. Thank you.
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a
computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
I just purchased a lasko model 5805 ceramic
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
