20 Most Recent General Electric DBXR463EG Dryer Questions & Answers
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
5/8/2012 3:39:10 PM • General Electric... • Answered on May 08, 2012
Need color coded wiring diagram
what happened to the wiring diagram that was located inside of the control panel
7/23/2011 8:12:47 PM • General Electric... • Answered on Jul 23, 2011
0answers
I have a GE electric
common problem is the rear bearing....http://www.youtube.com/watch?v=U7f8pF64008....copy and paste and watch the video,if this doesn't look like your machine,open the door and if there's two screws on the top remve them and pull off the top panel and everything else will be the same.
4/9/2011 9:12:22 PM • General Electric... • Answered on Apr 09, 2011
DRYER TAKES ALONG TIME TO DRY A LOAD OF CLOTHES IT
You may have a blower which is not circulating enough air flow. You can have heat and no blockage but a blower whcih is not moving enough air to distribute the heat and displace the moisture filled heat to the exterior.
3/29/2011 2:15:40 PM • General Electric... • Answered on Mar 29, 2011
Runs for a limited time
Your motor in the dryer is going bad ... it will just stop work one day
3/22/2011 9:11:58 PM • General Electric... • Answered on Mar 22, 2011
There is no clicking sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
11/23/2010 4:32:25 AM • General Electric... • Answered on Nov 23, 2010
How do I get to my fuse in my ge dryer?
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
11/16/2010 12:00:14 AM • General Electric... • Answered on Nov 16, 2010
No heat dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
9/30/2010 3:45:05 AM • General Electric... • Answered on Sep 30, 2010
Dryer shuting off in 5 min top getting very hot
Is the motor getting hot or is the element not shutting off?
If it is the motor then it is going bad...
If it is the element then the thermostat is bad and will just heat till the high limit shuts it down...then replace the thermostat and the high limit now that it has been activated...
here are a couple of tips that may also help you...
DryerRepair - The Dryer is not Turning
heatman101
9/15/2010 8:51:03 PM • General Electric... • Answered on Sep 15, 2010
When it first starts up it squels for a while,
There is a small plastic T-Bearing at the rear/center of the drum that often wears that could cause the noise.
Easy to replace,but be sure to add a little grease to it before putting drum back in.
At times it could also be the front drum glides,or even the plastic Idler wheel.
Look closely at them all when you have the drum out.
All these parts are relatively cheap to purchase.
Wigo.
center of the drum
3/4/2010 7:37:23 PM • General Electric... • Answered on Mar 04, 2010
2answers
Dryer comes on and blow but there is no heat, do I need to replac
Check the electic first. Check the thermal limit fuse. clean the machine of all lint. If the coil is bad you will see it is broken (burnt in two).
9/20/2009 1:16:44 PM • General Electric... • Answered on Sep 20, 2009
A few days ago our tumble dryer begun to make a
that could be anything you just have to unplug the dryer and get in there and see what happened,the belt pulley could have failed and jamming up the belt,first off does the dryer start?if so and the drum isn't spinning then the belt could be broke but this says it's a g.e. dryer so this has a safety switch in it that won't let the dryer run if the belt breaks,also g.e. has a rear bearing that fails,did you hear any sounds before like metal on metal,this could be alot of things,there's a front bulkhead with glides on it,i've seen the drum cut through the front of the dryer before, if you write back send the brand name and model number and anything else you heard before or take it apart and see what's up.if the dryer has alot going on with it don't buy another g.e. dryer get a whirlpool.
12/28/2017 2:29:35 PM • General Dryers • Answered on Dec 28, 2017
Ge dryer pcks433et1ww
That is a bad model number. Are you getting it off the tag in the machine?
1/3/2017 6:29:46 AM • General Dryers • Answered on Jan 03, 2017
General Electric DBXR463EG Dryer Logo
21 questions posted
Top General Dryers Experts
john h
Are you a General Dryer Expert? Answer questions, earn points and help others
View Most Popular
General Dryers
  • General Dryers
Most Popular Question
dryer shuting off in 5 min top getting
  • Dryers
