20 Most Recent
Nextar X3 GPS Receiver Questions & Answers
I Have nextat x3-t and want to ugrade it
Go to nextxt.com, and enter contact to check for all updates and upgrades for your unit. I did the same to upgrade my Garmin maps. They did charge for the service, but it was well worth it. Best of luck.
My nextar x3-01 will not turn on....can you help?
Hi.
The only thing you can do is attempting reset.
If that does not work, contact Nextar.
here reset instructions from manufacturer website:
Hi.
I quote from Nextar support:
"Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact Technical Support at 888-849-0846, if the problem cannot be resolved instructions as well as a Return Authorization will be issued for your defective product. No product will be accepted without prior authorization."
Will not go to the
Nextar is out of business so any kind of warranty you may have with them is probably void and null. Sorry!
I need to update my nextar X3-11 gps and dont know
Unfortunately Nextar does not offer an update for your unit. See units with available updates below.
Map Upgrades for GPS:
The below units are upgradable with the Navi Extra maps.
- Q4: From Serial #ML0909020001 onwards. From Serial #YF0909123953 onwards
- Q4-06: From Serial # ML0909000001 onwards
- ME: All serial numbers
- 43LT: All serial numbers
- V4: All serial numbers
- V5: All serial numbers
- I4-BC: From Serial# ML1004000001-ML1004000504 and ML1005001701-ML1005002700
Important Map Upgrade Information:
Please note that refurbished units that have serial numbers starting with MLR or ML999 are not compatible with map upgrades.
Navi Extra Mapping
Please note that Nextar is unable to answer map support questions once the Navi Extra mapping has been purchased. For any map related questions and/or refunds, please feel free to contact Navi Extra at:https://nextar.naviextras.com/shop/portal/support?selectedTab=contactus.
I have a nextar x3
First, take out any SD cards you may have in it. Pull the stylus out of the back, and use it to press the small RESET button between the SD slot and the stylus... hold it in about three seconds.
This will reset the unit.
Need download drive for nextar x3-08
There is not a driver available to download for this gps. You may try a hard reset which involves pressing the reset button located on the back or bottom with the tip of a paperclip for ten seconds. Otherwise the hardware or software may be corrupted and you will either need to return the unit for exchange or repair to the retail location from which you purchased it or contack nextar customer service to see how they can help you.
SCREEN IS FROZEN
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Dont know how to operate device. nextar gps
You can download the Hardware and Software manuals and the Quick Start Guide from the manufacturer's web site at
http://www.nextar.com/frontend/proddetailGPS.asp?pn=X3-09&co=10000385,10000312
Can you download a Quite
Hi there
You can download the manuals for your Nextar X3-08 GPS Navigation System
To Downloand please visit this link on Nextar website
There are three manuals available for free download
For getting help on short cuts and other features please refer to the "X3-08 Software.pdf" (bottom right-hand side of the web page)
This will resolve the issue you are facing.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
Regards
