20 Most Recent Haier CPRD12XC7 Air Conditioner Questions & Answers
Red light coming on ; tank is filling up. I drain
Fortunately, from what you have described, the unit is working as it should. But, the frequency that it's occurring is what I think you're concerned about.
If you are operating the Dehumidifier Mode along with the Cooling Mode, this will generate more water in the tank and require more frequent draining. Running the Dehumidifier and the AC (Cool) at the same time is not recommended. It reduces the cooling capacity of the AC Mode and generates heat in the room. And, as you already know, more water.
Hope this helps you and thanks for choosing FixYa.
7/10/2019 8:14:03 PM • Haier CPRD12XC7... • Answered on Jul 10, 2019
I bought this model and have used it very little.
You might have a bad motor ,bad capicator or even a bad board .Need to troubleshoot to find out .if there is power going to blower motor and it's not running then most likely motor is bad .
3/8/2018 1:42:09 PM • Haier CPRD12XC7... • Answered on Mar 08, 2018
We have Haier HPF12XM-LP cool/heat unit. We
hi.please you turn system in cooling mod and check compressor.maybe you must change capacitor compressor.you send capacity system to me.
10/26/2013 4:11:54 PM • Haier CPRD12XC7... • Answered on Oct 26, 2013
Fan capacitor
Granger
6/22/2013 10:55:20 PM • Haier CPRD12XC7... • Answered on Jun 22, 2013
I have a commercial cool
From what you have described it sounds like the room temperature sensor may be at fault. But, be usre you're seeing the room temp, rather than the temperature you have the unit set on.
In any event, Haier's Product Support Hotline can give you more details on the sensor and what part(s) may be needed.to make the repair or direct you to one of their authorized service locations You can reach them by dialing 1-877-337-3639
7/20/2011 9:40:48 PM • Haier CPRD12XC7... • Answered on Jul 20, 2011
The Exhaust fan is not working, the unit still
the unit is blowing cold air then tripping out, is it blowing hot air out the back? im sure you mean exhaust air as in hot air so the reason your unit is tripping out is that its overheating and the pressures in the rerigeration system are to high, so the safety trip cuts the unit off.
replace the motor
all the best
7/5/2010 10:13:21 PM • Haier CPRD12XC7... • Answered on Jul 05, 2010
Haier CWH24A. It isn't heating now that it's back on Heat mode
Question edited for clarity and add maker. Try a reset. Disconnect mains power for at least 2 hours. Reconnect and wait 5 minutes before turning on. This resets the mainboard and initiates a self test procedure. https://www.google.com/search?q=+Haier+CWH24A+not+heating+up ..
11/5/2023 9:53:52 PM • Haier Heating &... • Answered on Nov 05, 2023
Please my Haier Thermocool Ac automatically sets to 26c when I set it to 16 or any other number. It decreases slowly to 24 and stays there. Please what can be the cause of this? I need answers.
You will be able to get the answers from Haier support in your country. We are Fixya, not them. It sounds like a control board fault. You can try a reset. Turn it off at the breaker for 2 hours. Switch it back on and wait 5 minutes before turning the unit back on with the remote. https://www.google.com/search?q=Haier+Thermocool+AC ..
9/18/2023 6:30:27 PM • Haier Heating &... • Answered on Sep 18, 2023
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
11/8/2022 6:04:59 AM • Haier Heating &... • Answered on Nov 08, 2022
2answers
Remote for haier split- ac hsu-18dx"?
Window ac
9/20/2022 5:13:07 AM • Haier Heating &... • Answered on Sep 20, 2022
2answers
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
8/7/2022 5:21:47 AM • Haier Heating &... • Answered on Aug 07, 2022
Haier air conditioner fan turns off when compressor is off
switch fro auto to cool function.
7/21/2022 6:20:08 AM • Haier Heating &... • Answered on Jul 21, 2022
2answers
Haier portable AC keeps displaying FL error code, even after i empty the water bucket, WHY?
Having the same issue, it's a shame the only answer is telling you to do what you clearly said you had already tried.
6/23/2022 11:48:02 PM • Haier Heating &... • Answered on Jun 23, 2022
2answers
Brand new portable AC. AC compressor comes on but doesn't seem to be cooling for long
Take it back and get another one. Once you try to work on it, void the warranty.
6/9/2022 12:17:02 PM • Haier Heating &... • Answered on Jun 09, 2022
We have a wall mounted Hair air conditioning unit
This is a communication error between the indoor and out door units.
2/21/2022 5:21:30 AM • Haier Heating &... • Answered on Feb 21, 2022
Haier CPRD12XC7 Air Conditioner Logo
Popular Tags
13 questions posted
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Heating & Cooling
Most Popular Question
exhaust fan not working unit still
  • Heating & Cooling
