20 Most Recent
Amana PBE12 Wall/Window Air Conditioner Questions & Answers
How do i turn it on for the first time
hi there'
turning ac on,there are two switch on control panel of ac.find the thermostat control this signifies the room temperature you want,set this first to a maximum setting.another switch is for the motor compressor and fun motor.rotate the switch to fun first after a couple 15 second rotate again the switch to lo cool setting w8 for 10 to 15 sec. then rotae it again to hi cool there will be a sudden heavy change of blwing air and cooling effect then rotate set the thermosat switch to temperature comfortable to your feeling,observe the cycling process,because the compressor motor stop if the room temperature reached the set up temperature.stopping or switching off just rotate the switch of the compressor motor on off position.have a nice day fix my rate thank s a lot.
My unit is a heat pump that cools and heats.
if it is under warranty you could call the manufacture and put in a complaint. get the model and serial number and go online to get phone number. Let the manufacture know your not happy and to send somebody that can fix it. It sounds like you might have an intermintent problem meaning sometimes it can hard to diagnose. Be patient it will be fixed. there are alot of things it could be, so I can't tell you how to fix it unless I was to look at it myself. good luck
I'm not getting any code after installing a control board for my Amana ptac?
Does the power light come on?
If yes, then you can do a reset as below:
There is a master switch on the bottom left of the control board. Slide that to 'off' position.
Then press the hot and cold switch/key together and then slide the master switch back to 'on'.
Please put your response/observation here if that does not work or there is power light as asked on top.
Thanks
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
Amana Wall unit blows cold air before heating
The cold that you describe may be just unconditioned air? If you are certain you can hear the comp operating for a couple of minutes, and then the heat starts, I would guess it is a reversing valve issue if it's a heat pump and it probably is. Or the control board acting up. I've had a lot of issues with the boards in the Amanda PTAC units. I can't remember how to configure it, but if you Google "Amanda ptac configuration", there is a lot of info online. May try a reset method first. Hope this helps!
I have an Amana AP148D, can I run it without an
Self evaporating simply means there is a drain pan with a heater device installed that will evaporate and condensate that drains from the unit into the pan.
You do not need the external drain pan unless the unit makes more water than the drain pan and drain pan heater can handle.
I hav a amana ap148d and it shut off and the
Empty the water pan. It not sealed so dont slosh it around. Mine did the same thing. Amana rep was an ***. Wouldn't give me an inkling of what to do. So i started to fiddle around. There was a lot of water in it Be careful. I brought mine to the tub and drained it for close to 2 min. Started right back up!
