20 Most Recent
HP Pavilion tx2120US Tablet PC Questions & Answers
I have a HP tx2120 laptop and it seems to nly turn
this is the problem it needs reflowing. will not boot with this not connecting properly, and leaving this laptop on for long times like this it will shut down as you are cooking the board. and that will damage the board and other parts. might just be a better idea to change the board, if using windows 10 you need to install the original windows with the same windows key that your windows 10 was upgraded with or you will need to buy a new windows key.
My hp tx2120 us was
You may have finally run into the dreaded "defective GPU" issue, that plagued HP and other manufacturers. Thousands of defective Nvidia chip sets were used in the manufacture of these laptops and if you got one of these, it would last about a year, then fail, in the just the way you describe. If you were out of warranty, HP took the low road and refused to fix them, unless you ponied up $450. Then they replaced the defective motherboards with a new one, with exactly the same component.
If you have one of these, you will better of buying a new machine. I'd avoid HP though.
CD DVD stopeed working
Windows XP
- Click Start, and then click Run.
- In the Open box, type regedit, and then click OK.
- In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
- Exit Registry Editor.
- Restart the computer.
Tx2117cl, HP notebook and Touch screen, Webcam, Fingerprint Reade
The Update Dumped The Original Drivers
Look In Your Device Manager.... Start/Control Panel/System(you might need to switch to classic view to see the System icon in the Control Panel)..then the Hardware Tab.. then Click on Device Manager...
See If there are errors on the mentioned drivers...
You might need to go to HP website/Service and support/Drivers and software.... and redownload all mentioned drivers for your model of HP..
Microsoft Windows Xp professional Version 2002
Hello
I am not saying this is the correct solution for this problem, but it works for me every time.
First shut down the computer and unplug the power cord for about 5 minutes. Then boot up the computer again with the USB device plugged in. If this does not work, plug the USB device into one of the back ports of the computer case. By the way, have you installed the driver for the device? Hope this can help you.
Kind regards
Andrea
Unlock code for build alot 2?
There is no unlock code, you will get a patch for it, send me comment on this with your email address and I will send it to you on your email.
I cannot find ethernet driver
im not quite shure if this is what you are looking for but it is a Driver for a vewsonic viewpad 1000 however it is only for the operating system windows XP and below, however if you are running vista you can still try it. it is possible that it may work for vista.
you can find it and download it by following this link >
http://members.driverguide.com/driver/detail.php?driverid=334738
only thing is in order to get it youll need to select Download this file by viewing a series of ads (no registration required) and it is FREE.
Hope this solves your problem Good Luck.
Reguards: PC Pro
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
