20 Most Recent
Sony BRAVIA® DAV-HDX277WC Theater System with Wireless Speakers Questions & Answers
Won't do anything! push power
One of the speaker outputs are burnt,need power board replacment (audio output board, not power supply) don't replace components on board since is very difficult
Can you use this system with a laptop for stereo
Your only choice is most likely a 3.5mm minijack cable. Take the laptop to a Radishack and make sure that cable will fit. The Sony should have an input for that cable even if it is the headphone jack. If your laptop has other audio outputs like an RCA or hdmi, which is unlikely, you would connect one of those cables between it and the Sony (Sony's input).
Dav-hdx277wc power protector keeps coming
Why don't you try it without any speakers connected. That would prove if the problem is internal or external. Then either isolate the external speaker path that's causing it or get the unit fixed (internal).
Can the sony bravia home theater system be
Strickly speaking about the audio:
The unit has digital audio in on 1 each coaxial and digital connectors.
Most DVD players have digital audio out in either a coaxial (RCA-looking) cable or optical cable.
Consider this: your TV is not a Source of audio (or even video, if you think about it). You probably get your programming from a cable or satellite box, Its audio should be available digitally.
If your DVD and cable use DIFFERENT types of digital audio sources, you're in luck. Attach each one to its compatible input on the Bravia. If you only have two optical outputs you can only attach one at a time.
If you have only two COAXIAL digital audio sources you CAN combine them into a single digital input on the Bravia by getting an RCA-splitter cable to connect them both to the one connector. It will only work if you leave one source dormant or off at any time you're monitoring the other source, otherwise you'll have two digital 'converstions' going on with the Bravia at the same time and it won't be pretty.
I want to connect my laptop with HDX277WC sony
Your laptop only has an stereo output so it is not possible. I don't know if there is any gadget that you can connect to the usb, and get a surround output from a computer. You may wana check that out, and if there exist such a device it surely would have a software to go along with it.
Hook up Sony Bravia Home Theater DAV-HDX277WC
Hi....I haven't hooked mine to the TV yet.....building my cabinet now....but I did hook up the components to make sure they worked and just didnt include a TV on it. My S-Air wireless linked up the first time I tried it....I will say this though, the little wireless transceivers blocks you have to plug into the DVD player and the S-Air do not go in like you would think. They actually look like they are upside down when you get them in, and the must snap in very securely. Make sure they dont just LOOK like they are plugged in. Also, dont get em to far away through too many walls, Try linking it sitting right close to the DVD. Also remember the S-Air remote has its own volume control as well as other controls....
I know I wasnt much help but I just got mine and I will be back with more after I try the surround sound on the TV.
I just bought a Sony Home Theater DAV seris but
most all theater systems come with a remote and it,s odd that your,s did not, usually their are certain functions that you can control from the head unit ,but nowadays you can program a universal remote to your brand that will be able to control the functions of your theater system ,but to make things easier, call the customer service dept of sony and tell them your model# and purchase it direct from the manufactuer, this remote will have set-up functions for your dvd menu,s and will be easier then having to get up off the couch to change settings , thank you ,hope this helped glenn
