20 Most Recent Samsung HT-AS720ST Theater System Questions & Answers
0answers
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
9/27/2013 7:15:26 PM • Samsung... • Answered on Sep 27, 2013
The volume cannot exceed 10 almost no sound coming
Make sure the wiring is making clean connections between the speakers and the unit.
9/13/2013 2:46:38 PM • Samsung... • Answered on Sep 13, 2013
3answers
Static in speaker channel on my Samsung Surround Sound system
our started cracking and popping this morning. It seems from all the posts that it is always the right front speaker. With that kind of trend it can be traced back to mfg. Is there a recall, are they covering the cost?
10/16/2012 4:33:14 PM • Samsung... • Answered on Oct 16, 2012
Samsung HT AS720ST Surround system - Volume problems
I have the same problem. HDMI connection and the sound just stops. Very frustrating
5/22/2012 4:56:48 PM • Samsung... • Answered on May 22, 2012
0answers
We have a samsung AVR
Disconnect all wires to the receiver and speakers and connect them back again. The receiver should be on a surround or 5.1 mode
5/3/2011 1:34:35 AM • Samsung... • Answered on May 03, 2011
Hi, I own An HT-AS720ST surround System. I just
Hissing is cused by noise interference which is usually bad cableing or bad reception of the station or device if wireless then check out your hosehold appliances and start shutting them off one at a time and see if that clears it up. Somethng is tagging along for the ride on the same freq or close to the freq if wireless
2/16/2011 6:05:42 AM • Samsung... • Answered on Feb 16, 2011
Have been trying to connect
http://www.retrevo.com/support/Samsung-HT-AS720-Home-Theater-Systems-manual/id/6333ci454/t/2/
Page 10 discusses speaker connection.
Disconnect everything but the speakers and evaluate the buzz. It may be coming from external hardware or loosely connected analog cables.
Sometime juts rotating the ac plug on one device eliminates the ground loop buzz.
2/7/2011 8:18:07 PM • Samsung... • Answered on Feb 07, 2011
When I go on SATHDMI2, SATOPTIC2, DVDHDMI1,
12/27/2010 10:47:04 PM • Samsung... • Answered on Dec 27, 2010
Static coming from the front
I had this same issue about a year after I bought the product. Sent it back under warranty and about a year later, I have the exact same issue again. Never buying samsung receivers again.
12/16/2010 6:57:25 PM • Samsung... • Answered on Dec 16, 2010
2answers
The front right speaker channel on my Samsung
IF it is out of warranty, you can open it up and look for loose connectors on the boards. It may be a poor connection that is visible. Otherwise it may be a connection problem that is hidden/internal. Bad solder connection on the board/speaker tabs, etc.
10/21/2010 10:16:34 PM • Samsung... • Answered on Oct 21, 2010
Samsung HT-AS720ST Theater System Logo
30 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
trying connect
  • Audio Players & Recorders
