20 Most Recent
Viking VCSB483 Side by Side Refrigerator Questions & Answers
Fan keeps running
freezer fan runs when freezer calls for cooling
ref fan runs when fridge calls for cooling
condenser fan up top runs with compressor
lower unit condensate fan runs with compressor
fans should not be noisy
control monitors temp and will give alarm if temp rise
please contact viking as your fridge may have a safety recall on door hinges
Viking freezing evaporator coil
im not sure if still is the case.but there used to be a timer that shuts off the refridge so it self defrost. it is set to do this 1ce a day so the ice or frost does not build up.it is called a defrost timer. if it fails it will not shut down the fridge.most of them are near the front behind the grate.
How to I start the fridge
It should start automatically when plugged in. If it doesn't test the outlet to make sure it's providing power.
It beeps randomly - the same beep when the door is
are you getting any display codes or warning lights?? It may just need the cond coil cleaned up top.
Find the switch that the door hits to shut off the lights. push it to see if the lights go out. It could be a bad lite switch
Vcsb483
if you remove the center part of the grill you will then find four 1/4" screws on the black back section remove them then loosen the bolts one on the right and left and the switch is going to be on the right side. The reason I am telling you to take off the whole grill vs just the center is that you are going to need to clean the condensor that is going to be on the left side at the top. IMPORTANT ONLY CLEAN THE CONDENSOR IN AN UP DOWN MOTION DO NOT GO ACROSS AS THIS WILL DAMAGE THE FINS.
Thank you and have a great day,
Sabastian
