20 Most Recent
Viking VDSC307-4B Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Any ideas?
I would attempt to replace the relay switch. Manual switch 220 V is dangerous so relays are used. Follow the wiring back from the element to the relay. If that fails get a repair guy out for an estimate. Tough to figure out without physically witnessing unit.
8/20/2009 3:57:57 PM •
Viking...
Answered
on Aug 20, 2009
Self clean burnout
1758, have the technician start with the terminal block. This is where the power is hooked to the range. Check for loose connections, cracks, burnt wires. Are you sure the board and relays are burnt out? Have him check the thermal disk that sits on top of the oven cavity. If this is open, no heat. In the past I had to move or elevate these TCO's away from the vent. I would use two small nuts to elevate it from the oven body to prevent it opening during cleaning. These are just a couple of things to check. Catriver...post back.
11/13/2006 4:47:13 PM •
Viking...
Answered
on Nov 13, 2006
How to turn-off the self cleaning on an Eaton viking 1997 range
To turn off the self-cleaning cycle on your Eaton Viking 1997 range, follow these steps:
- Press the "Off/Clear" button to stop the self-cleaning cycle.
- Wait for the oven to cool down completely. The self-cleaning cycle can take several hours, so it's best to wait at least a few hours before attempting to turn it off.
- Open the oven door and remove the racks.
- Use a damp cloth to wipe away any remaining debris or ash from the oven walls and bottom.
- Close the oven door and press the "Off/Clear" button again to reset the oven.
- Your Eaton Viking range should now be back to normal and ready for use.
Viking gas oven won't shut off
It sounds like you are experiencing an issue with your Viking VGSC486-6Q gas oven where the gas continues to flow and the oven continues to heat even after the desired temperature has been reached. This can be a dangerous issue, as it can cause the oven to overheat and potentially start a fire. Here are a few steps you can try to troubleshoot the issue:
- Check the oven sensor: The oven sensor is responsible for measuring the temperature inside the oven and sending a signal to the control board to adjust the gas flow and heat as needed. If the sensor is not functioning properly, it can cause the oven to continue heating even after the desired temperature has been reached. You can try cleaning the sensor with a dry cloth and making sure it is securely connected to the control board.
- Check the control board: The control board is responsible for receiving the signal from the oven sensor and adjusting the gas flow and heat accordingly. If the control board is faulty, it can cause the oven to continue heating even after the desired temperature has been reached. You can try resetting the control board by unplugging the oven and plugging it back in, or you may need to replace the control board.
- Check the gas valve: The gas valve is responsible for regulating the flow of gas to the oven. If the gas valve is faulty, it can cause the oven to continue heating even after the desired temperature has been reached. You can try cleaning the gas valve and making sure it is securely connected, or you may need to replace the gas valve.
If none of these steps help resolve the issue, it may be necessary to have the oven repaired by a professional. It is important to address this issue as soon as possible, as it can be dangerous to use an oven that continues to heat even after the desired temperature has been reached.
