20 Most Recent
3Com NBX 3101 Questions & Answers
Nbx auto answer
Hi,At Two scenarios it will be happening.1. When your phones act as a intercom.2. When your server settings are enabled with auto-answer option.Check with server admin.-Karthik.
Change the time on the clock
This must be done on the phone system as the administrator. For 6.0 software go to System-wide settings, set date and time, and you can set it there. For 5.0 and older, go to Tab to it, System configuration, system settings, date and time. Once the time has been set on the phone system the date is updated instantly on the phones (even before your browser finished loading the next page).
Call Forwarding --Help
The phone may be apart of a hunt group. Inside of the Net Set Utility, check to see if it is a member of that hunt group.
Voicemail in use message
Reboot the phone system (through the browser) and this should take care of it. There are limited voicemail ports and sometimes they get put on hold and can't be released. I have seen it a lot. some versions of software can clear this but a reboot will take care of it.
11/11/2013 11:49:24 PM •
3Com NBX...
Answered
on Nov 11, 2013
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
