20 Most Recent Carrier 38CKC030 Air Conditioner Questions & Answers
5answers
Tube running from AC unit to the house is
You either have a refrigerant leak or a dirty inside coil or a slow running inside blower motor.
Set the thermostat for heat and run it until all the ice is thawed. Then check the incoming air side of the coil for lint and dirt. Check the fan motor for proper speed. If you have service gauges your low side pressure should be approximately 68 psi. If lower you have a leak.
12/16/2017 1:20:14 AM • Carrier 38CKC030... • Answered on Dec 16, 2017
My screen on the air
Check power supply is going to PCB. If yes, repair or replace PCB
10/31/2013 3:01:14 PM • Carrier 38CKC030... • Answered on Oct 31, 2013
4answers
My carrier air conditioning unit does not cool below 72 degrees
there is a leak and need to fix it before you can charge it
5/29/2012 9:45:24 PM • Carrier 38CKC030... • Answered on May 29, 2012
Problem with frozen coil
Hello, the evaporator will freeze from either low airflow or a low refrigerant charge. Check the air filter, blower whell to make sure it is clean and air is movimg freely. If the unit is clean and filter is clean then the unit is low on refrigerant due to a leak and will need to be rechaged.
8/8/2011 2:10:40 AM • Carrier 38CKC030... • Answered on Aug 08, 2011
No cool air is coming out of vents. Checked
Yes let the ice melt on the evap coil and the outside line. You either have a low charge or you might check your filter dryer on the outside lines this could be stopped up. you will will have a temp drop across the filter if it is stopped up. If not it is possible to be low on charge. Is the inside fan turning and turning the right direction. If the inside fan is not turning it will cause the evap coil to freeze up.
7/27/2011 4:39:46 PM • Carrier 38CKC030... • Answered on Jul 27, 2011
2answers
Pipe to the compressor keeps
Normal. High humidity and warm days will cause this You can wash it off it will make you feel better. but don't worry about it . Hope this helps Jon
7/26/2011 2:28:45 PM • Carrier 38CKC030... • Answered on Jul 26, 2011
I have a carrier 38ckc030 air conditioner. the
you are right replace the compressor/fan capacitor this helps compressor/ fan start its the round silver or oval part in the condensor ..let me know ..good luck/joe/
8/26/2010 10:08:05 PM • Carrier 38CKC030... • Answered on Aug 26, 2010
Furnace stopped blowing cold.
Hi!!
Replace motor fan and capacitor, it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300+. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
8/13/2010 4:55:59 PM • Carrier 38CKC030... • Answered on Aug 13, 2010
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
7/8/2010 3:03:20 AM • Carrier 38CKC030... • Answered on Jul 08, 2010
My Carrier air conditioner condenser unit model
Check the contactor........it is possible the contacts are wearing..........the contactor is considered a wear-n-tear item.
7/3/2010 3:24:09 AM • Carrier 38CKC030... • Answered on Jul 03, 2010
Not blowing cold air
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioning2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
6/25/2010 4:52:34 AM • Carrier 38CKC030... • Answered on Jun 25, 2010
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
6/11/2010 3:07:21 PM • Carrier 38CKC030... • Answered on Jun 11, 2010
Turned unit on for first time, it will not kick on
does the indoor fan blow? If it does you are getting the 24 volts from the thermostat to the ouside contactor need to check your contactor in the oustide unit this is what kicks on the compressor it take the 24 volts and goes to 230 volts to run the compressor and condensor fan. check your schematic for the placement of the contactor.
6/4/2010 5:42:24 PM • Carrier 38CKC030... • Answered on Jun 04, 2010
38cks is blowing air but it's not cooling
First thing, are the filters clean? If so then you have lost some gas from the system and need to find and repair the leak, and put in correct gas charge.
5/21/2010 4:43:54 AM • Carrier 38CKC030... • Answered on May 21, 2010
Carrier 38CKC030 Air Conditioner Logo
35 questions posted
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Heating & Cooling
Most Popular Question
furnace stopped blowing cold
  • Heating & Cooling
