20 Most Recent
Whirlpool WFC7500VW Washer Questions & Answers
Push start and machine wont fill and
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
7/13/2021 12:24:49 AM •
Whirlpool...
Answered
on Jul 13, 2021
Hi , im getting the a10 error code on the
Gfontanelli, we're sorry to learn that you're receiving an error code on your Washer. Thank you for your review. We would like to discuss this further with you. Please email us at
[email protected] at your earliest convenience with your user name Gfontanelli , name, address, a phone number and best time to reach you along with your model and serial number.
10/31/2017 8:07:03 PM •
Whirlpool...
Answered
on Oct 31, 2017
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
7/28/2017 9:36:21 PM •
Whirlpool...
Answered
on Jul 28, 2017
Error code F-05
The error translates as "NTC faulty. Check thermostat and associated wiring." What it actually means it your water heater has almost certainly failed.
8/26/2016 9:51:21 PM •
Whirlpool...
Answered
on Aug 26, 2016
Front knob for whirlpool washer wfc7500vw broken?
Hi,most washing machines open from the top,a couple of screws at the back and slide the top back and lift,then you should be able to see the part number,I hope this is the same for your machine.
all the best.
3/7/2016 7:17:43 AM •
Whirlpool...
Answered
on Mar 07, 2016
What does error code f-01 mean
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Generally in order to correct this failure the CCU board will need to be replaced.
Before you cal the repairman, try unplugging the washer for 3 minutes and then power up again and see if the error clears.
Good luck.
5/11/2015 3:38:33 PM •
Whirlpool...
Answered
on May 11, 2015
Error code F 06
Hope this helps... I found it on an appliance blog that I go to from time to time.
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
2/14/2015 6:38:21 PM •
Whirlpool...
Answered
on Feb 14, 2015
What is f-22
F22 means you have a door lock problem you need to unlock your door to correct the problem
6/24/2014 4:49:42 AM •
Whirlpool...
Answered
on Jun 24, 2014
