20 Most Recent
Fisher and Paykel WL37T26D Top Load Washer Questions & Answers
Fisher & Paykel Smart Drive Pride 5.5 Top Load turns off?
That sounds indicative or either a failed controller board or bad connections on it. What you can try if you wish is getting to the control board and spraying all the connecters with electrical switch cleaner. For any board edge connectors remove the connector, spray the contacts on the board edge and polish the board edge contact strips with a piece of kitchen towel. If that doesn't fix it call for service and diagnosis as control boards are expensive, so you need not only a correct diagnoses but warranty on the part and the labour.
The other possibility as an afterthought, as the drain blockage caused this, is the pump working okay? These machines have self test procedures on the pump, and if the pump doesn't pass, the machine shuts down. If the drain was blocked and the pump was running for an extending time, it may be heat stressed. That would be a much cheaper repair.
Further ideas in this link
https://www.google.com/search?q=Fisher+%26+Paykel+Smart+Drive+Pride+5.5+Top+Load+turns+off+after+filling
