20 Most Recent Frigidaire FTF2140F Front Load Washer Questions & Answers
2answers
Frigidaire washer ftf2140fs2 lights on the right side keep beeping washer wont start
Hello 2cats - First, is the drain pump making a humming noise? If so, the unit could possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Other possibilities could be a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
12/24/2020 3:51:45 PM • Frigidaire... • Answered on Dec 24, 2020
2answers
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
2/3/2018 7:30:57 PM • Frigidaire... • Answered on Feb 03, 2018
Frigidaire frontload FTF2140ES3 33 month old,
If the bearing is bad it will likely do one of three things, it can sound like a jet is taking off when your washer is spinning, the rear bearing seal can start leaking, or if it is really bad there will be slop between the basket and tub. Open the door and spin the basket, does it sound like the bearing has gravel in it? Lift on the basket if it has slop between the basket and tub this will for sure cause the banging you are talking about. To verify the leak you will have to pull the rear cover off of the machine and look for grease or water trails running down the rear of the tub. Often times the grease or water will get on the pulley or belt and fling it around the rear of the washer. Hope this helps.
12/4/2017 2:14:33 AM • Frigidaire... • Answered on Dec 04, 2017
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
2/12/2013 4:51:17 PM • Frigidaire... • Answered on Feb 12, 2013
Frigidaire front load washer will rinse but not spin
Does it give any error code, or flashing lights?
8/29/2012 9:39:06 PM • Frigidaire... • Answered on Aug 29, 2012
Frigidaire FTF2140FS2 all lights come on and washer doesn't start
Do you notice any error codes?
7/30/2012 3:24:14 PM • Frigidaire... • Answered on Jul 30, 2012
The washer agitates, but then
The washer will not spin if it cannot drain the water. There is a filter in the hose from the tub that leads to the pump. You can access it from the front by removing the front lower panerl. Remove the large, black rubber hose on the bottom of the tub and the filter will pull out. Water will come out, so be prepared!
Kelly
3/24/2011 10:55:38 PM • Frigidaire... • Answered on Mar 24, 2011
It does not finish its cycle and gives an er20
You have an error code that is e20. that is a problem with the pump, or drain hose. Go to web site below and download the file it will show you how to fix it.
http://www.mediafire.com/?0gy1jnemjdp the clamp on the coin trap can be a pain, take it off last with vise grips and put it on first, that way you can just keep the vise grips locked on the ******
3/15/2011 9:49:02 PM • Frigidaire... • Answered on Mar 15, 2011
The rubber seal is black
Have you tied Affresh? That will do the job nicely.
1/18/2011 8:29:22 PM • Frigidaire... • Answered on Jan 18, 2011
Will not spin and belt is in good condition
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
6/18/2010 3:44:43 AM • Frigidaire... • Answered on Jun 18, 2010
It shakes so violently, it knocked 2 holes in the
take bottom panel off,check the shocks,if it is making loud noise it's probably spider gear,if you keep using it the boot could rip off and you'll have a flood,get rid of washer it will cost as much to fix washer that you could buy a new one but that's up to you to decide
11/6/2009 7:28:24 PM • Frigidaire... • Answered on Nov 06, 2009
2answers
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you! I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
3/20/2024 3:24:35 AM • Frigidaire... • Answered on Mar 20, 2024
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2/11/2024 4:24:20 PM • Frigidaire... • Answered on Feb 11, 2024
My Frigidaire FWAC 19B5MSGNW washing machine won't move on from the spin cycle. The light is on and if I fill it up with water it will pump out the water but the spin light will not come off.
The machine does not exist as you have written it. There are two likely reasons The door switch has failed and hasn't passed the self test procedure. or the control board / timer has failed. Try power cycling it. Remove the mains plug for an hour. It is has an On Off button press it for a minute. For a knob, full it and leave two minutes. Plug back in and try again. https://www.google.com/search?q=Frigidaire+FWAC+19B5MSGNW ..
1/2/2024 11:12:23 PM • Frigidaire... • Answered on Jan 02, 2024
Frigidaire front load washer door locked
crowbar?
5/15/2023 1:33:24 PM • Frigidaire... • Answered on May 15, 2023
Frigidaire FTF2140F Front Load Washer Logo
25 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
washer agitates but
  • Washing Machines
