The F35
indicates that the main control board detects a problem with the analog
pressure sensor (water level pressure switch) in the washer. This
component senses and controls water level in the washer. This failure
could
be caused by a pinched or broken air hose between the air trap at the
bottom of the washer tub and the analog pressure sensor. It can also be
caused by a clogged air trap or a failed analog pressure sensor. If you
are able to unplug the washer and pull off the top panel, you can
check for the probable cause of this failure.
To remove the top
panel,
remove the screws on the very back of the panel that secure it to the
washer
cabinet. Pull the top panel back slightly and then and off of the
washer. It is on the side wall just behind the expansion control board.
You
can check the air pressure hose connection and the wire harness
connection on this component.
This component costs around
$99.This information was based on the general description of the washer
model that you provided (Kenmore Elite front load washer). There are
several different models of this washer.
The following link
explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_errorNOTE:
If these preliminary measures do not correct your problem, you may
have to replace the drain pump. It does not take much to damage the
pump impeller or motor. Since the error code can be generated if the
drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at
the required volume, the error code will continue to appear until the
pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
