20 Most Recent
General Electric WBVH5200J Front Load Washer Questions & Answers
Burnt resistors on mother board
the fact is that no manufacturer will give you part nos ion safety and legal reasons the only way is to go to a scap yard and y=try to find the same scrap machine for the circuit board, the value of the resistors is irrelevant as they burnt out for a reason that replacement resistors wont fix eric
Will not rinse,i have to
Use vinegar in lieu of fabric softener!!! It not only is cheaper, but it will NOT cause the clothes to smell like a Caesar salad, it removes 99.9% of detergent, it softens the clothes, and its much better for people with sensitivities.
Ge wbvh5200j3ww
Hi Jennifer,Here is a link to the USER'S MANUAL for that model of washer:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90392-2.pdfJust click on the underlined text above to view an electronic copy of the manual.On page 8 of that manual you will see instructions related to the LOCK feature on your washer.It says that to LOCK or UNLOCK the washer, just hold down the DELAY START button for 3 seconds. The lock icon on the display should then disappear.If that does not work for your model, then try holding down the SIGNAL button for 3 seconds.One of these two procedures should solve your problem.
Hope that helps.Take care and t
hank you for using FIXYA.Joe.
No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
