20 Most Recent
Fisher and Paykel WA37TG1 Top Load Stacked Washer / Dryer Questions & Answers
About a week ago I
Hi
In my opinion
This would be the water level sensor as the water should not get that high were it goes over the top the sensor should cut in and shut the water off at the level you set.
The problem can create more and can be dangerous as water and electricity not good best get it looked at.
regards Craig
Will not drain
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
I have a Fisher & Paykel AquaSmart top loading
Hi just read your posting.What cycle are you using for the towels?Have you tried a cycle with the EFFICIENCY turned OFF?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Fisher/Paykel WA37TG1 washer. goes through the
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Fisher & Paykel Smart Drive Pride 5.5 Top Load turns off?
That sounds indicative or either a failed controller board or bad connections on it. What you can try if you wish is getting to the control board and spraying all the connecters with electrical switch cleaner. For any board edge connectors remove the connector, spray the contacts on the board edge and polish the board edge contact strips with a piece of kitchen towel. If that doesn't fix it call for service and diagnosis as control boards are expensive, so you need not only a correct diagnoses but warranty on the part and the labour.
The other possibility as an afterthought, as the drain blockage caused this, is the pump working okay? These machines have self test procedures on the pump, and if the pump doesn't pass, the machine shuts down. If the drain was blocked and the pump was running for an extending time, it may be heat stressed. That would be a much cheaper repair.
Further ideas in this link
https://www.google.com/search?q=Fisher+%26+Paykel+Smart+Drive+Pride+5.5+Top+Load+turns+off+after+filling
