20 Most Recent
Jura Capresso Jura / Capresso IMPRESSA Z6 Espresso Machine Questions & Answers
Capresso C 3000 order of water lines for dispensers
Unfortunately, without being there in person to inspect the machine and its components, it's difficult for me to provide a definitive answer. However, I can offer some general guidance that may help:
- Consult the user manual: The user manual for your Capresso C3000 should have a diagram or schematic showing the different components and their connections. If you still have the manual, check to see if there's a helpful diagram inside.
- Look for visual cues: While it can be difficult to identify the tubes by sight alone, there may be visual cues that can help you narrow down which tubes go where. For example, one tube may be thicker or more flexible than the others, or it may have a different color or texture.
- Experiment with different configurations: If you're unable to find a diagram or visual cues, you may need to experiment with different configurations until you find the correct one. This can be time-consuming and frustrating, but it may be the only option if you're unable to find any other information.
- Seek professional help: If you're still unable to identify the correct tube configuration, you may want to consider seeking professional help. A qualified technician or repair service may be able to identify the correct configuration and get your machine back up and running.
I hope this helps, and I wish you the best of luck in getting your Capresso C3000 back in working order!
