20 Most Recent
Bunn AXIOM AXIOM-DV-APS Coffee Maker Questions & Answers
Hot water faucet adjustment?
The Axiom uses a water level probe to keep the heater tank filled with water at a set level. The hot water facet takes water directly from the top of the tank. It's gravity fed with only the weight of the top portion of the water (the hottest area) to flow into the faucet. It is possible that your faucet 'Boot' or spring is bad and needs replacement. But it's designed to give you a single cup of hot water. Do not expect to fill a pot (or large french press) with this faucet.
* Call your vendor for service.
Aloha, ukeboy57
(the parts manual) https://catalog.bunn.com/public/docs/39131.0000/E17/01/000/39131.0000.pdf
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
