20 Most Recent
Bunn 38700.0008 Questions & Answers
I need info on installing
You will need to tap into an existing water line. It is reccomended that you use a 3/8" braided tubing. You can get everythin you need from lowes. First you will need to know how far you have to run the hose and what size the existing water line is. You could just tell the people at lowes or home depot or a local hardware store what you need and they can provide you with the proper equipment, usually just a quick connect or barbed tee, hose and clamps. You may have to drill holes through you cabinets and counter. Hope this helps.
WWW.MidstateBeverage.com
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
