20 Most Recent Krups XP7230 Compact Super Automatic Espresso Machine Questions & Answers
ChoccyBar,
THANK YOU. You're answer was so helpful. I have the XP7230 and all of the sudden had exact same problem, machine wouldn't not register a full tank. After reading this I checked the floating piece and saw that it was not floating with a full tank like it is supposed to. Had to obstruct it to keep it afloat as well, and voila, it worked.
Ahh... what a relief to have my machine working again. Coffee has never tasted so good.
Krups XP7230... | Answered on Mar 15, 2019
Has been said a foolish person and their money are soon parted .. perhaps KRUPS can suggest what is wrong FIXYA can not SORRY
Krups XP7230... | Answered on Sep 30, 2017
Code 05 for my KRUPS EA 8050?
Krups XP7230... | Answered on Feb 24, 2017
no normal fix it requires worshop inetervention to replace the seal
Krups XP7230... | Answered on Jan 06, 2017
Nothing happens.
Krups XP7230... | Answered on Aug 28, 2016
You need a special Torx screwdriver to access the insides of this machine, T10 and T15 from memory. Your best bet is to find a proper service agent who has experience with this model, they are NOT simple to work on. There are a lot of repairers who will not take them on so choose someone who is happy to do it and has experience on them. Best person would be whoever does them for Krups in your locality. The failure is nothing at all to do with you, it was going to happen no matter who was using it. The luckiest fault I can think of for you is a broken O ring seal on the tamping piston, you only need the top off to fix that. If it is that seal buy the correct part, they are quite a soft seal by comparison the what you get in a box of assorted O rings.
Krups XP7230... | Answered on Mar 08, 2015
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Krups XP7230... | Answered on Feb 02, 2015
There are many places for the water to leak out the bottom on those. You are going to need to remove the covers and have a look. Is the water clean or is it part of your brew? In order of most likely to least likely
1) Barista seal at bottom of brew chamber
2) Distributor
3) Tank seal
4) Tamping piston seals
5) Flexible hose or connection
6) Hydraulic Ram
7) Relief valve on end of pump
You are not going to figure it out with the covers on and you will have great difficulty running it with covers off to be certain where it is coming from but that is what most of those issues is going to require.
Krups XP7230... | Answered on Jul 18, 2014
0C
Faulty communication between the 2
boards
Disconnect and reconnect the
coffee-maker
Overconsumption on low voltage power
supply: Distributor blocked, does not turn
Determine the cause
Krups XP7230... | Answered on Mar 01, 2014
Faulty communication between the 2 pcbs or distributor is drawing too much current
Krups XP7230... | Answered on Dec 20, 2013
Let it build some steam first .
Krups XP7230... | Answered on Nov 02, 2013
I have a xp7240 which I believe has the same housing as yours. I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. The valve that leaks is on the bottom of the machine (will cost you a lot of time to get to it. Don't know the replacement price.) Good luck!
Krups XP7230... | Answered on Sep 30, 2013
Krups XP7230 Compact Super Automatic Espresso Machine Logo
83 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
XP Krups
  • XP Krups
Most Popular Question
water recipient full
  • Coffee Makers & Espresso Machines
