20 Most Recent
Lang Manufacturing PB-24-S Questions & Answers
I need to know the power requirements for this
It is single phase. Either 208 volts 3240 watts or 240 volts 4316 watts. Unfortunately, its difficult to know which one you have. It can be ordered either way. Here's the deal, For no apparent reason, some buildings have 208 volts, some have 240 volts. If you know when you buy new equipment, you specify which voltage you have. So if your building has 208 volts and the machine is 240, it will still work, maybe a little slower to heat up. If it is the other way around, your building has 240 volts and the machine has 208 elements, it will heat up much faster, but the life of the elements is drastacally reduced becuse they burn out much quicker. You can call Lang at 314 781 2777 ask for technical assistance and they may have a way to find the voltage if the tag is missing.
10/19/2010 1:06:05 PM •
Lang...
Answered
on Oct 19, 2010
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
3 days ago
Paragon spin magic 5qr, when spinning causes bowl to shift.
Athletes often talk about the need to find "the zone." This is a state where everything seems to come together and they are able to achieve feats they never thought possible. For bowlers, this zone is often referred to as "the spin zone." When bowlers are able to get their bowling ball to rotate quickly on the lane, they can cause the ball to move in unexpected ways.
2/8/2024 2:23:46 PM •
Kitchen...
Answered
on Feb 08, 2024
Gett motor out of toledo meat slicer
Removing the motor from a Toledo meat slicer involves several steps. First, unplug the slicer to ensure safety. Locate the motor, typically positioned near the base. Depending on the model, you may need to remove a cover or access panel to reveal the motor. Disconnect any electrical connections, such as wires or cables, linked to the motor. Next, loosen and remove any securing bolts or screws holding the motor in place. Carefully lift the motor out of its housing, ensuring that no other components are obstructing its removal. Exercise caution and refer to the specific user manual for your Toledo meat slicer model for precise instructions.
2/3/2024 5:14:04 AM •
Kitchen...
Answered
on Feb 03, 2024
