20 Most Recent KitchenAid K5AWH Stand Mixer Questions & Answers
K5a kitchenaid
To adjust the K-5A, there is no little screw under the motor head. However, you can easily adjust it by tightening the 7/16 bolt that is accessible under the mixer base. Simply lay over the mixer (after unplugging it), use a 7/16 long head socket and extension, and tighten a 1/4 turn at a time to raise the bowl. FYI, we've had this mixer for 20 years and I've never done it before. Mine took 6 separate 1/4 turns (totaling 1 1/2) turns to move the dime slightly on each rotation. Works great now!
12/21/2019 8:04:18 PM • KitchenAid K5AWH... • Answered on Dec 21, 2019
Motors continue to go out. No notice or anything,
When you say that the "motor's continue to go out," do you mean that the motor itself stops working or that the motor still runs but the beater stops turning? These are two different problems. Take a look at this Service Manual which is correct for your model and see if it helps: http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
2/2/2018 8:05:43 PM • KitchenAid K5AWH... • Answered on Feb 02, 2018
2answers
The capacitor on the speed switch is burning out.
I have found that the capacitor is no longer available, along with
any of the motor parts. Armature, brushes, motor end bearing, etc, are not available.
5/9/2014 4:48:33 PM • KitchenAid K5AWH... • Answered on May 09, 2014
2answers
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
9/18/2013 4:20:34 AM • KitchenAid K5AWH... • Answered on Sep 18, 2013
2answers
I need the wiring diagram. my son took it apart
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Not sure if it is your model but the wiring is basically the same and the pictures help too.
7/18/2012 4:04:36 PM • KitchenAid K5AWH... • Answered on Jul 18, 2012
I have an older K5-A
See the following:http://dir.groups.yahoo.com/group/WACEM/message/28365
7/18/2012 3:58:26 PM • KitchenAid K5AWH... • Answered on Jul 18, 2012
2answers
Kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
6/8/2012 4:44:31 PM • KitchenAid K5AWH... • Answered on Jun 08, 2012
I have the KitchenAid 5
hello step ..... yes. You may have to adjust the height of the bowl a wee bit as it sounds like the dough hook is hitting the side of the bowl..
It tells the steps in your manual.
Easy to do.
If you don't have the manual you can download it for free here http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Joe
3/12/2011 3:10:37 PM • KitchenAid K5AWH... • Answered on Mar 12, 2011
Seized mixer
It sounds like a stripped gear. Altho I can't find the parts diagram for the K5Awh I have found the diagram for the similar mixer with the lift bowl feature. Check the diagram below and make sure it is similar to your K5 machine since there are two designs for the motor on the lift bowl.
Look at the diagram below and find 9709231 worm gear item #18 in:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
It is the one which usually strips. It can be purchased online for between 12 and 25 dollars so check the part number and put it into google to find the best price. Let me know if the motor design is different from what is shown in this parts list.
Take it apart first and see which gear is stripped.
http://www.misterfixit.com
alternate parts list is:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10168434.pdf
and the gear number is
W10112253
4/15/2010 5:52:08 PM • KitchenAid K5AWH... • Answered on Apr 15, 2010
Motor does not move.
It is most likely a problem with dirty brushes. Check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
4/7/2010 7:12:56 PM • KitchenAid K5AWH... • Answered on Apr 07, 2010
KitchenAid Professional 5 Quart stand mixer grain mill won't grind?
From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears. https://www.google.com/search?q=olympus+s924+manual A Moulinex Coffee Mill might be a better solution for grinding wheat. ..
4/16/2023 11:16:47 PM • KitchenAid Food... • Answered on Apr 16, 2023
New Artisan Kitchenaid mixer KSM150 out of the box, head won't lock.
Don't forget if it is new it is under manufacturer warranty. Make the beater isn't too low and fouling, because the bowl is set too high? Try to lock with no beater.
3/25/2023 5:11:48 AM • KitchenAid Food... • Answered on Mar 25, 2023
3answers
Trying to adjust the beater to bowl clearance on my bowl lift KitchenAid K5SS. Mine has only pairs of screws, unlike manual diagram
Possibly one screw for up and one for down, working on a see-saw mechanism.
2/6/2023 9:52:44 PM • KitchenAid Food... • Answered on Feb 06, 2023
How to convert kitchenaid mixer from 220v to 110v
It's perfectly save to use a power converter from 220v to 110V. The 50Hz Frequenz will let the Motor spin 20% slower. So it'll last forever. I use a KSM90 from the US in Germany for more than 25 years. It runs great and the gears inside it look like new.
2/5/2023 12:30:16 PM • KitchenAid Food... • Answered on Feb 05, 2023
Kitchenaid Professional 6 Quart Mixer. The speed lever is stuck.
Question edited for clarity. Question moved to category. The speed lever is electronic. Videos and the part in the link. https://www.google.com/search?q=Kitchenaid+Professional+6+mixer+speed+lever+stuck ..
12/19/2022 12:42:07 AM • KitchenAid Food... • Answered on Dec 19, 2022
3answers
Kitchenaid mixer repair manual
google kv25g0xwh manual
7/30/2022 5:31:02 AM • KitchenAid Food... • Answered on Jul 30, 2022
KitchenAid K5AWH Stand Mixer Logo
Popular Tags
16 questions posted
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
k5a kitchenaid
  • Food Mixers
