20 Most Recent Maytag MMV5207 Microwave Oven Questions & Answers
0answers
2answers
Display blank, power source OK.
A thermal switch probably sensed the temp as too high and opened. If it did not reset when cooled down then the thermal switch is of the type that required replacement. Take it to a repair shop unless you are capable of making electrical checks and doing this safely.
1/25/2014 6:28:22 PM • Maytag MMV5207... • Answered on Jan 25, 2014
0answers
0answers
0answers
Timer functions, fan works, great humming noise,
If there is no heat at all, but you can hear the magnetron humming, it is probably bad. if there is uneven heat, the wave stirrer that distributes the microwaves around the cooking chamber may be bad. it will heat only one spot unless the wave stirrer is rotating.
11/20/2010 2:46:26 AM • Maytag MMV5207... • Answered on Nov 20, 2010
My microwave suddenly stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jh
9/30/2010 9:44:33 PM • Maytag MMV5207... • Answered on Sep 30, 2010
No heat and noise
heatman101
adf
9/30/2010 2:17:43 PM • Maytag MMV5207... • Answered on Sep 30, 2010
Powers up, but no heat.
its most likley to be the magnatron burn out,,,
thats the part that heats the food up,,its a pricy part to buy and have fitted it may be better to buy a new unit
6/20/2010 9:52:35 PM • Maytag MMV5207... • Answered on Jun 20, 2010
3answers
I have Maytag Model CMV
HI, you can use this link to see the next step to take.
(ehow.com/how_112488_diagnose-microwave-oven.html).
It will guide you through.
Take care.
6/11/2010 2:50:58 AM • Maytag MMV5207... • Answered on Jun 11, 2010
REPLACED A BLOWN NIGHT LIGHT BULB - EVER SINCE IT
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too, as well as other functions.
1/31/2010 5:52:52 PM • Maytag MMV5207... • Answered on Jan 31, 2010
INTERNAL LIGHT DOES NOT COME ON WHEN MICROWAVE IS
the bulb can be taken out from inside the oven just open the boor and look inside for a grill behind this is a light bulb, sorted easy
10/22/2009 3:21:29 AM • Maytag MMV5207... • Answered on Oct 22, 2009
I need to know the size of the lightbulb for
The bulb is a halogen (part number 53001905). You can view the bulb at searspartsdirect.com. Type in your model number and look under the "Base/Latch Board Assembly" heading for item 6. Although it does not list the size, it does list the type and part number. Your hardware store may be able to cross this number for you and find the bulb you need.
PS There is a better view of the bulb at appliancepartspros.com. Just type in the part number above and you will see a photograph. Are you in Canada? If so, you may enquire one of these sites also to see if they will ship to Canada.
7/27/2009 10:22:07 PM • Maytag MMV5207... • Answered on Jul 27, 2009
E5 error code microwave
On my Microwave it saying e5 on it and it not reheating it self
11/6/2023 8:04:40 AM • Maytag Microwave... • Answered on Nov 06, 2023
Maytag MMV5207 Microwave Oven Logo
28 questions posted
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
display blank power source ok
  • Microwave Ovens
