20 Most Recent Gladiator Freezer GAFZ21XXRK Questions & Answers
0answers
Fan will not run
Be the first to answer 11/14/2011 4:46:05 PM • Gladiator... • Posted on Nov 14, 2011Be the first to answer
Gladiator Model No. XXRK-
Gladiators are a unique breed from any other style of refrigerator for their convertible capabilities of altering which section you wish to be the fresh food or the freezer, and the ability to use it in colder ambient temperatures than a typical residential refrigerator. This unique capability requires the use of a reversible fan motor and and dampers as well as additional foam insulation. If the door was left open, you have likely a buildup of frost and or ice in these air ducts as a result. My advice, empty it out, unplug it, open BOTH doors, blow a fan into the cabinet for a minimum of 24 hours. The water coming from the suction line of the compressor could be a sign that there is a little too much refrigerant in the system, or that it is in a fairly warm area, or near some source of heat.
10/4/2010 11:32:03 PM • Gladiator... • Answered on Oct 04, 2010
2answers
My Gladiator Freezerator is iceing
It looks like the problem is from the fan, it is either the evaporator fan is not blowing or the fan is loose or covered with dust.
The fan is is at the back of the refrigerator, look at the bottom of the refrigerator, at the back, you will see the compressor and the fan.
Take care.
8/6/2010 4:37:45 PM • Gladiator... • Answered on Aug 06, 2010
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
9/28/2009 2:27:38 AM • Gladiator... • Answered on Sep 28, 2009
Gladiator 21 cubic ft. The bottom is freezing
it may be to enclosed, to close to wall, try moving it, also clean under it every 2 months, coild attract dust like mad
9/28/2009 1:52:43 AM • Gladiator... • Answered on Sep 28, 2009
Freezer with loose red and blue cables
All question need full 'make model (what it is)', first 3 words. Google make model wiring diagram. Brown or Red is normally power and blue is return. https://www.google.com/search?q=Freezer+with+loose+red+and+blue+cables ..
4/22/2024 11:19:39 PM • Freezers • Answered Yesterday
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Norfrost C6AEW Chest Freezer. Wiring help please.
Question edited for clarity and add CAPS. It seems to be a common occurrence on that model due to bad design. https://www.fixya.com/support/t17110008-norfrost_c6aew_chest_freezer_compressor Norfrost is owned by Ebac. Contact their customer service. https://www.johnogroat-journal.co.uk/news/caithness-freezer-name-lives-on-in-england-170710/ https://www.ebac.com/support/customer-service Another way would be to study the wiring as it is pretty standard. The video may help. https://www.google.com/search?q=freezer+wiring+diagram You may be able to freeze this video to note the wiring, although this only shows the thermostat wiring and is a bit fuzzy. Also an refrigeration appliance technician would know the wiring by heart and take 20 minutes maximum to work it out.
2/11/2024 5:45:01 PM • Freezers • Answered on Feb 11, 2024
2answers
Norfrost c6aew chest freezer compressor wiring
Hey. I dont suppose you figured out where the wires went all all? I've done the same thing ???? img-20240210-wa0019-hnmqxmichaytgjvoydy3hl3m-d-0.jpg img-20240210-wa0018-hnmqxmichaytgjvoydy3hl3m-d-1.jpg img-20240210-wa0020-hnmqxmichaytgjvoydy3hl3m-d-2.jpg
2/11/2024 12:01:33 PM • Freezers • Answered on Feb 11, 2024
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words. That is an overheating fault. Replace the fluff with no fluff. Make sure the condenser coils are free of dust and there is good airflow Or It is low on refrigerant gas and you need a service tech.. ..
2/3/2024 5:25:13 AM • Freezers • Answered on Feb 03, 2024
Cubic feet of a fridgeadare chest freezer- FFC13K2CW1
The Frigidaire FFC13K2CW1 chest freezer has a capacity of 12.8 cubic feet. More info: https://www.partselect.com/Models/FFC13K2CW1/
1/22/2024 2:51:52 PM • Freezers • Answered on Jan 22, 2024
One of the drawers in my upright freezer BRADA MF-305 broke. Is it possible to replace it please?
Question edited for clarity. Duplicate question deleted. Refresh page to see you question. This is not a make I know. Things like drawers are usually readily available. This link may work better where you are located. https://www.google.com/search?q=BRADA+MF-305+parts Generic Drawer replacements https://www.google.ca/search?q=freezer+drawer+replacement&sca_esv=580628691&tbm=isch&sxsrf=AM9HkKk2I1HuWqUimTZskQkh3tRH3AJ6rA:1699481832834&source=lnms&sa=X&ved=2ahUKEwiZ0MqXt7WCAxUwL1kFHUrtBG0Q_AUoAnoECAIQBA&biw=1920&bih=919&dpr=1 ..
11/8/2023 10:18:51 PM • Freezers • Answered on Nov 08, 2023
My chest freezer will not freeze food on top layer or in basket
Is it on Economy Mode? That only chills the bottom area. Check the condenser fins are cleaned of dust. That needs doing every 6 months. Or it needs refrigerant gas. ..
10/5/2023 3:35:25 AM • Freezers • Answered on Oct 05, 2023
I would like to know when will Walmart Canada online have the Arctic King 7.0 Chest Freezer E-Star back in stock?
Question edited for clarity. Question moved from Star Computers. Greetings from Toronto! It is made by Midea and sold to Walmart as a batch, "make us 10,000 at $100 each. We will sell for $280 until they are gone". All the retailers are out of stock including Amazon and Wilson's Home Store. Choose another make and model, bottom of this page. Home Depot, Leon's or The Brick are a good bet for Freezers. https://www.dontwasteyourmoney.com/products/arctic-king-arc070s0arbb-7-cubic-feet-chest-deep-freezer/
8/18/2023 11:46:21 PM • Freezers • Answered on Aug 18, 2023
2answers
There is water accumulated in my Norfrost Aura chest freezer. How do I drain it?
There is normally a drain plug on the lower rear or sides. You probably have leaking door gasket. https://www.google.com/search?q=norfrost+aura+chest+freezer+drain+hole+location ..
8/18/2023 7:11:29 AM • Freezers • Answered on Aug 18, 2023
Gladiator Freezer GAFZ21XXRK Logo
10 questions posted
Top Gladiator Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Gladiator Freezer Expert? Answer questions, earn points and help others
View Most Popular
Gladiator Freezers
  • Gladiator Freezers
Most Popular Question
gladiator model no xxrk
  • Freezers
