20 Most Recent LG LRE30453ST (Electric) Stainless Steel Range Questions & Answers
My recently purchased LG electric range came witho...
It is rare for a Range Mfg. to supply pots/pans/or other cooking instruments with their products. Yes, you should have saved the old hardware. I suggest you seek new cookware from eBay, Amazon, or WalMart.
1/12/2018 7:29:25 PM • LG LRE30453ST... • Answered on Jan 12, 2018
0answers
My LG electric range overheats every time it is turned on
If the sensor you changed is the rod type one in the oven itself then the only other thing possible is the control board where you set the temperature. The sensor works with that board to control oven temp.
1/8/2017 6:08:44 PM • LG LRE30453ST... • Answered on Jan 08, 2017
Where is the baking element?
Hi Joe, I bought an electric stove/oven. I got it home and same thing as you mate.... It took me a while to find the oven element which was underneath the bottom of the oven, I never seen or heard of one before or since until you mate.... I have no idea how to get to it I suppose you just lay the stove/oven over on it's side and go through the bottom............CHEERS..
4/25/2016 2:17:59 PM • LG LRE30453ST... • Answered on Apr 25, 2016
Left front burner is not turning on at all.
Gas - smell if gas is coming out and turn lights out and see if ignitor is working ,
Electric- check the wire plug connecting to burner element .
Then resubmitt your question
12/19/2015 6:00:18 PM • LG LRE30453ST... • Answered on Dec 19, 2015
I replaced the relay board because the relay on t relay on the far right was burnt and melted where the black wire connects. now my new relay board burnt and melted the same place. what can be the pr
Hello. I looked up your model range and found many service bulletins associated with it. Among those was a RECALL due to burn/fire hazards from the burners not shutting off and the temperature setting can increase unexpectedly. The model years affected were from January 2006 to June 2010. I've attached a pic of the affected serial numbers. You can obtain a free in-home repair by contacting LG at (855) 400-4038, toll free. I hope this helps you! 24955629-u522pwk5rdpunusrfvvhxrnx-5-0.jpg
9/18/2015 2:15:47 AM • LG LRE30453ST... • Answered on Sep 18, 2015
I own an LG30453ST/01 range oven. I recently replaced the temperature sensor and now set the oven temp to 400 degrees and it takes a long time to get there. do you know what the problem might be?
Check if the sensor is properly installed in a proper position. It may not detect the proper heat temperature if it is not a proper positon.
3/20/2015 2:05:49 PM • LG LRE30453ST... • Answered on Mar 20, 2015
2answers
Lost manual for lg range.need
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.lg.com/us/appliances/ranges/LG-electric-range-LRE30453ST.jsp
To view the Support Page just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
To download and view the Owner's Manual with operating instructions, just click on the SUPPORT button on the right hand side of the main support page when you get there.
Then click on the ENGLISH button under DOCUMENTS - RANGES MANUAL.
When it asks you if you want to open or save the document, select SAVE and then choose a place on your computer to save it like the DESKTOP so you can find it easily later.
When the download completes, click OPEN, and then you can view the contents of the manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there and then follow the onscreen instructions to istall it.
See page 25 of the OWNER'S MANUAL for detailed instructions and illustrations on how to carry out the SELF CLEAN procedure.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
12/30/2014 3:31:00 AM • LG LRE30453ST... • Answered on Dec 30, 2014
0answers
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
1/8/2014 12:31:13 AM • LG LRE30453ST... • Answered on Jan 08, 2014
LG LRE30453ST (Electric) Stainless Steel Range Logo
65 questions posted
Top LG Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
LG Kitchen Ranges
  • LG Kitchen Ranges
Most Popular Question
own lg30453st 01 range oven recently
  • Kitchen Ranges
