20 Most Recent Jackson 10APRB 36 in. Dishwasher Questions & Answers
I must have the only Jackson model 10a that is
Try Ali Baba web site they have a lot of hard to find parts you must use any numbers on original part or mfg part # .
1/10/2018 3:15:49 AM • Jackson 10APRB... • Answered on Jan 10, 2018
manual
Have a Jackson tempstar hh that has a problem where the rinse contactor will not shut off even though the thermostat to the booster heater is not calling. The contactor is not stuck.
Sounds like the valve itself is stuck open. Shut off the water to the dishmachine, remove the solenoid coil, get a pipe wrench or large crescent wrench and open the top of the rinse valve. Either get some muriatic acid or some strong lime away and clean the internal valve. Make sure to put the parts back in the correct way. The top of the valve has a piston and a spring. DO not lose either of them. The bottom of the valve has a diaphram and a valve seat. remove both of these clean them so that they move freely. Install all the parts exactly like you found them. Tighten down the valve, put the coil back on and turn on the water
5/25/2019 2:30:01 PM • Jackson... • Answered on May 25, 2019
Looking for someone to answer my question, can I put sheet pans through my Jackson Tempstar dishmachine
Contact the manufacturer. FIXYA uses unpaid volunteers throughtout the world who try to answer questions for free. FIXYA volunteers do not work for manufacturers or sell washing machines or other appliances. Phone: 888.800.5672 Mailing Address: 6209 N U.S. Hwy 25E Gray, KY 40734 Online form to send questions: https://www.jacksonwws.com/contact/ Contact Jackson WWS
4/4/2018 4:30:42 PM • Jackson... • Answered on Apr 04, 2018
Jackson Tempstar Dishwasher side door not closing properly. There is a gap on the top.
Is it possible someone has accidentally leant on the door? I would take side panels off and check if hinges are bent
1/12/2018 9:38:46 AM • Jackson... • Answered on Jan 12, 2018
I am a new tenant in a building with a round Jackson dishwasher. I'm trying to follow the instructions. I can see two strainers, one round, and the other cylindrical. I've looked at the manual
You have neglected to include the model number which you must have if you have the manual. Jackson produced a number of models. That said, here is a site that may help you because it shows where parts go in a schematic: Wash Rinse Assembly Contact Jackson WWS
11/18/2017 7:16:32 AM • Jackson... • Answered on Nov 18, 2017
Our church (St Philip's) has
all height modifications are possible i dont care what anyone else says it can be done. If you need further help, reach me via phone at https://www.6ya.com/expert/scott_8b3f0f0fc5f566a7
9/18/2017 3:29:58 AM • Jackson... • Answered on Sep 18, 2017
0answers
Hooking up a dema pro V to a jackson 150B 220 3 PHS machine. What should the voltage be off the dsp1 & dsp2 terminals & what should the common voltage be?
Are you sure you have 3phase power available? there should be 220 between all three.
3/6/2015 5:03:32 PM • Jackson... • Answered on Mar 06, 2015
Jackson 10APRB 36 in. Dishwasher Logo
6 questions posted
Top Jackson Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
Bonded Repair
Don A
Don A
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Jackson Dishwashers
  • Jackson Dishwashers
Most Popular Question
must only jackson model 10a
  • Dishwashers
