20 Most Recent Polar FS1 Unisex Heart Rate Monitor Watch Questions & Answers
In was trying to replace my battery and the little
Here is a video that shows the entire process of replacing the battery in the Polar fs1. It shows the little plate and where to place it.
5/17/2012 1:15:54 AM • Polar FS1 Unisex... • Answered on May 17, 2012
2answers
How do you put the back, back onto this fs1? The
You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
5/17/2012 1:12:46 AM • Polar FS1 Unisex... • Answered on May 17, 2012
Can not turn on
Then it needs a new battery or some sort of repair. The button on the face turns the monitor on for use, if this doesn't work, then you need to replace something.
4/25/2011 4:13:11 PM • Polar FS1 Unisex... • Answered on Apr 25, 2011
How dod I get the
send your watch to an Authorized Polar Service Center, these are not designed to be user serviceable.
3/20/2011 7:28:08 PM • Polar FS1 Unisex... • Answered on Mar 20, 2011
The heart monitor drops to
replace the battery on the chest belt and make sure its tight enough. another thing is that you need to wet the pads on the belt for it to work properly.
also I mentioned the battery, if the battery is low it may not have enought power to transmit unless you hold it near the watch.
2/9/2011 5:52:34 PM • Polar FS1 Unisex... • Answered on Feb 09, 2011
I HAVE LOST THE MANUAL.FOR FS1 POLOR WATCH. HOW DO
You can get a copy of the user manual by going to their web site- link http://www.polarusa.com/us-en/support/downloads?product=&category=User+manuals.
Fill in your model name and download.
1/11/2011 5:34:15 PM • Polar FS1 Unisex... • Answered on Jan 11, 2011
My watch does not show heart rate
I have a problem solving checklist about getting Heart rate readings in my tips and tricks page that may be helpful.
#1) you have to make sure the strap is across your chest and contacting the skin directly
#2) you have to push the button on the front of your watch to turn it on.
After that it should read automatically, there is no trick to your watch.
1/4/2011 4:15:13 AM • Polar FS1 Unisex... • Answered on Jan 04, 2011
I am trying to set
On my tips and tricks page is a link to the user manual.
The trick with the FS1 is that you have to wait between button pushes. Don't try to skip ahead of the pace of the watch, it is slow to set anything. That is the rub with 1 button operations.
Push the button, wait for the prompt, enter the info, push the button, wait for the prompt, etc.
if after trying this it still doesn't work you will either need to take it back and exchange or send into polar. There is a warranty service available. Again that link is under my tips and tricks.
12/15/2010 3:35:43 PM • Polar FS1 Unisex... • Answered on Dec 15, 2010
How to change battery
mcdevito75 here, Battery change is once every year or so, even if you changed thr battery now, you"d forget next year, I know I did. BEST BET, look for a small watch repair shop in your area for the peace of mind. Approx. cost, $10.00-- $15.00
10/26/2010 8:42:30 PM • Polar FS1 Unisex... • Answered on Oct 26, 2010
Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
7/15/2010 10:22:07 PM • Polar FS1 Unisex... • Answered on Jul 15, 2010
No operating instructions for Polar FS1
If you go to http://www.polarusa.com/us-en/support/downloads?product=&category=User+manuals
You will see a drop down list. Scroll down to find the instructions for your model.
5/15/2010 9:52:29 AM • Polar FS1 Unisex... • Answered on May 15, 2010
How do I change the battery in a Polar FS1 Heart
Like most makers, they recommend that you have batteries changed at one of there service centers (to retain the waterproof seal.
Some people have problems when refitting the backs of watches and come onto this site to find out how they can get their watch going again. The cost saving does not seem worth the risk of damaging your watch. If your watch is still under warranty, then it will be invalidated by unauthorised repairs.
To find your near service center, go to Ploar.com and click on "support" and then "service" and "retail finder.
1/30/2010 6:38:27 PM • Polar FS1 Unisex... • Answered on Jan 30, 2010
Which way round does the battery go in a Polar FS1
Battry must go - (minus) into the movement and +(plus) facing up. As battery replacement must be done with watch upside down, you must see the +(plus) on battery when it is inserted into the movement and the fit the contact over it.
Do not forget to rate, please.
3/11/2009 5:06:15 PM • Polar FS1 Unisex... • Answered on Mar 11, 2009
Polar AXN300: the graphic barometer trend does not change anymore after changing the battery.
Hi, Please check that the batteries that you're using are compatible with your watch. Also, you can check whether the battery is oriented properly based on the + and - signs. Thank you.
10/7/2022 8:37:52 PM • Polar Watches • Answered on Oct 07, 2022
Polar FS1 Unisex Heart Rate Monitor Watch Logo
Popular Tags
23 questions posted
Top Polar Watches Experts
NOEL
NOEL
vince
Alex Kimuyu
Are you a Polar Watch Expert? Answer questions, earn points and help others
View Most Popular
Polar Watches
  • Polar Watches
Most Popular Question
put back back onto fs1
  • Watches
