20 Most Recent
Comdial Impact 8012S Corded Phone Questions & Answers
Programming Ext #'s
hit the options key till you get to query then hit the intercom key or just intercom the operator and see what extension it comes up with
How to establish extensions?
The extensions start at 10 , and if you press the speaker button and hold it for a second or two it will show the extension number in the LCD display . If you do not have any phones with a display you have to find it by pressing the intercom button and try dialing the extensions one by one .
Comdial edge 120 incoming call handling help
It seems like you're trying to configure a phone system or a specific phone to have incoming calls ring on multiple extensions simultaneously or forward to another extension if not answered. The exact steps can vary depending on the phone system or model you're using. If you provide more details about the phone system or model, I can offer more accurate instructions. In the absence of specific information, here's a general guide on how you might achieve this:
**For Most Phone Systems:**
1. **Ring All Extensions:**
- Log in to the phone system's administration interface.
- Locate the call forwarding or call distribution settings.
- Look for options related to "Hunt Group," "Ring Group," "Call Distribution," or similar terms.
- Create a group that includes the extensions you want the incoming calls to ring on.
- Assign the group a number or label.
- Configure incoming calls to be forwarded to the assigned group number or label.
2. **Forward After Rings/No Answer:**
- Within the same settings area, look for options related to "Call Forwarding" or "Follow Me."
- Configure the settings to forward calls to another extension or voicemail after a certain number of rings or if there's no answer.
**Example for Asterisk-based Systems (such as FreePBX):**
- Log in to the FreePBX administration interface.
- Create a Ring Group.
- Add the extensions you want to include in the group.
- Set the Ring Strategy to "Ringall" or "Ring All Available."
- Specify the Ring Time (how long it should ring on each extension).
- Save the settings.
- Create a Follow Me setting.
- Add the destination extension(s).
- Set the Ring Time (how many seconds it should ring).
- Configure the Follow Me List to go to the next destination if there's no answer.
Please note that terminology and options might differ based on your phone system's manufacturer and model. It's important to consult your phone system's documentation or seek help from your IT department or phone system administrator if you're not familiar with the settings or if you're dealing with a complex setup.
Keep in mind that making changes to a phone system's configuration can impact its functionality, so it's a good practice to do so during non-peak hours or with proper testing to ensure everything works as expected.
I need help resetting the password to my Comdial 7260 00 voicemail.
To reset the password on your Comdial 7260 00 voicemail, follow these steps:
- Dial the voicemail extension from your phone.
- When prompted, enter the default password. The default password is usually "0000" or "1234".
- Follow the prompts to change your password. If you are not prompted to change your password, press "9" for the mailbox options menu, then "8" for the password menu.
- Enter your new password when prompted. Make sure to choose a secure password that you can remember.
- Confirm your new password when prompted.
- Hang up the phone to save your changes.
If you are still having trouble resetting your password, you may need to contact your voicemail administrator or Comdial customer support for further assistance.
