20 Most Recent Crosley CA10WXP Air Conditioner Questions & Answers
After running the A/C for
Many of the newer A/C window units do not drain the water, but use the fan to splash it up on the coil to evaporate it and help cool the unit...
You can drill a hole in the back corner to drain it, but watch that you don't hit the coil and cause a freon leak...this also may reduce the efficiency a bit...
heatman101
8/23/2011 1:49:23 AM • Crosley CA10WXP... • Answered on Aug 23, 2011
I need a part# for a run capacitor for a Crosley CAE25ESR
2007 made"? 15 years old5304459575 capacitordual cap run/herm ( fan/compressor)fdhttps://ecommcdnprod.azureedge.net/model-documents/bapg_electrolux_product_support/CAE/CAE25ESR2/5995497418.pdfread the old cap and post uf/uf and volts. the manual keeps that a secret25,000btuwindow A/cold.read the old parts words and share the, or is it burned up?bingo5304459575 Dual Run CapacitorFrigidaire Part Number 5304459575 Dual Run Capacitor.jk65-0196r,50uf+8uf,370vac,2?w 5.5?h overalldeep deep deep searching found ithttps://appliancemasters.com/ac/product/5304459575/subs are easyor use 2 caps. sure can, 370vac or more50uf- compr.8uf fan./most appliance parts store online have them.
8/4/2022 2:52:21 PM • Crosley Heating... • Answered on Aug 04, 2022
Crosley AC / Heat split system. Air is fine, no heat. How to get working please?
Question edited for clarity. Question moved to Crosley category. Try turning it off at the breaker for 2 hours to reset the system. Leave 15 minutes before trying it so it can do its self testing. If that doesn't fix it, you need a service engineer.
11/19/2021 2:56:11 AM • Crosley Heating... • Answered on Nov 19, 2021
A crosley 18,000 cool and heat window unit it turns off with remote or on the unit but it keeps on making a small sound when I unplug it it goes off what is the problem?
A small sound huh??? Help us help you. Maybe it’s the reversing valve disengaging
9/27/2021 6:20:25 PM • Crosley Heating... • Answered on Sep 27, 2021
3answers
Why does the reset button on my air conditioner keep popping out when i plug it in
You are tripping that outlet's breaker. Either too much is on that breaker and circuit or that circuit is not big enough, enough current to power that unit.
7/17/2021 8:55:17 AM • Crosley Heating... • Answered on Jul 17, 2021
I've misplaced the User Manual for my Crosley Portable Air Conditioner Model CPTE14A1 and my hubs is furious. I can't seem to find it online. Can you assist me please?? Marlene in Oregon
Hello, Marlene - I suggest you locate the Crosley dealer nearest you and selling portable air conditioners and ask if you can purchase a replacement user manual for your model. See this web page to find the Crosley dealers in your area: https://www.crosley.com/dealerlocator.html Best wishes.
6/23/2018 12:09:33 AM • Crosley Heating... • Answered on Jun 23, 2018
Crosley CAE12ESR air conditioner turn on but not blowing air. Only making buzzing sound. Cool and fan not working.
You can try this. Remove the cover, spin the fan by hand and see if the motor runs well after this, if so, the capacitor or motor condensor is bad or has defective wiring. Replacing it should take care of the problem. Some capacitors are split capacitors, have two values and serve both a fan motor and the compressor. In this case, the unit can be rewired for individual capacitors or the split one replaced.
5/1/2015 12:29:29 AM • Crosley Heating... • Answered on May 01, 2015
2answers
Where is the drain on a crosley air conditioner?
Since the water runs down the evaporator coils its located at the lowest part of the unit. either in the center underneath it, or at the rear edge. The drain does get plugged up and the evap coils get dirty as well. When its installed in the window it should be installed so its tipped slightly backwards so if the pan get full of wate, the overflow will run out the back and not into the house.
8/28/2014 8:56:11 PM • Crosley Heating... • Answered on Aug 28, 2014
How can' I reset or fix my ac that will not turn off unless unplugging it?
There Is a micro processor inside and it gives you ten seconds to push the off button after you leave it unplugged for around 7 hours turn it off leave plugged in and will reset only while it off bad unplugged and I fixed this ac myself and no one could tell me what to do I asked a question and finally figured it out myself this my answer to my question
7/28/2014 9:28:35 PM • Crosley Heating... • Answered on Jul 28, 2014
The unit won't come on.
There might be something wrong with the wiring connection. Check for open wire, burn-out wire or worn-out terminal lug from your control box. Unplug the unit and unscrew the control box to find the problem.If you found nothing abnormal plug it in and test with volt meter if power is coming at the end of the wires (connected to the plug). If no power at the end of the wires, it is broken near the plug. Cut the wire and reconnect it back to a new plug.
9/2/2011 12:08:18 AM • Crosley Heating... • Answered on Sep 02, 2011
I need to know wich
look on the data plate it will tell you the refrigerant.. its R/22 i bet... if its a real new one it may have the 410-A .but very doubtful because its a window unit ..let me know ..good luck/joe/
8/25/2010 10:29:56 PM • Crosley Heating... • Answered on Aug 25, 2010
How much tilt does the
3 to 4 degrees
4/26/2009 4:32:32 PM • Crosley Heating... • Answered on Apr 26, 2009
Crosley CA10WXP Air Conditioner Logo
1 questions posted
Top Crosley Heating & Cooling Experts
Paul Carew
john h
Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Heating & Cooling
Most Popular Question
after running c
  • Heating & Cooling
