20 Most Recent Evenflo ExerSaucer SmartSteps ABC Stroller Questions & Answers
4answers
Can't locate the battery in the evenflo mega exersaucer to change
I have found a way to replace the batteries on the monkey truck. First of all you have to consider if it is worth it. The monkey / banana truck takes three (3) LR44 batteries. I have looked and found these to cost $4.50 to $5.50 each. If you choose to continue, please read all the way through the directions before continuing. Although my method does not require removing the decals, it does require damage to them.
1. Remove the truck from the Exersaucer. The base has four tabs that need to be slightly deflected to remove the base.
2. Turn the base over and remove the four screws holding the truck to the base. Remove the truck from the base.
3. Using a utility knife and following the seam in the plastic, make a slice down the center of the windshield decal and the back window decal.
4. Using a #1 Phillips head screwdriver, poke a hole in the decals of the front and rear driver's side windows. The hole is to be located halfway down the window, and an 1/8" (3mm) from the back or rear of the window respectively. In each hole, there is a Phillips head screw to be removed.
5. Remove the screw in each wheel on the driver's side.
6. Separate the two halves of the truck body, remove the center assembly. It may be stuck due to the glue on the side window decals. The yellow and red lights can be pushed out from the outside of the truck.
7. Locating the circuit board you can see the three batteries under retainers.
8. Remove the four screws holding the circuit board to the center assembly.
9. Bend up two tabs on the battery retainers and push the batteries out of the retainers.
10. Replace the batteries.
11. Reassemble in reverse order.
3/23/2014 8:42:18 PM • Evenflo... • Answered on Mar 23, 2014
How do i take the seat cover off?
Have you looked on YouTube? Or if kiddiecare sells the pram they always have videos showing how to do things :) xx
11/11/2012 8:33:55 AM • Evenflo... • Answered on Nov 11, 2012
I am looking for the
Both Amazon.com and E-bay.com have switch a roos for this product. There are apples, stars, fish, and many more on E-bay that are buy now products.
5/17/2011 6:08:27 AM • Evenflo... • Answered on May 17, 2011
2answers
I need a manual for
evenflo.com should have manual for download or shipping.
5/7/2011 7:52:29 PM • Evenflo... • Answered on May 07, 2011
I am looking for a replacement toy for the one
Try eBay I've seen all sorts of parts show up there.
11/30/2010 5:07:28 AM • Evenflo... • Answered on Nov 30, 2010
I have a old 3
Evenflo - ExersaucerInstructions:
- evenflo.com/ShowDocument.aspx?ManualID=234
- evenflo.com/resource.aspx?id=467&rcid=19
I hopw helps with this; remember to rate this answer. Good luck.
10/3/2010 4:07:06 PM • Evenflo... • Answered on Oct 03, 2010
I just purchased a used exer saucer and don't know
Wasn't aware that you could fold it up---probably meant to stay open.
2/28/2010 12:08:09 AM • Evenflo... • Answered on Feb 28, 2010
4answers
I installed the seat cover
Hello. The only way to correct the problem is to disassemble the stroller, reposition the cover and then reassemble. A real pain for sure. Sorry there is no quicker fix for you. Regards, Joe
1/31/2010 5:16:19 AM • Evenflo... • Answered on Jan 31, 2010
Lost the directions to turn the toy into stage 3.
flip it over,there has to b a way to unclip the bottom.
11/18/2009 8:15:10 AM • Evenflo... • Answered on Nov 18, 2009
Don't know how to reattach the cloth seat to the
flip it upside down look for holes for tabs to slide in & hook to a lil hook to hold it in place. take notes next time u take it apart,i learnd that after 2 kids n have to take apart carseats to wash them.
11/18/2009 8:12:36 AM • Evenflo... • Answered on Nov 18, 2009
We took the seat out of the evenflo exersaucer and
fill it up side down,u'll c holes for tabs to go in & connect to a lil hook to hold it.
11/18/2009 8:09:24 AM • Evenflo... • Answered on Nov 18, 2009
I lost the instructions to our evenflo exersaucer 3-1
if you go on the evenflo wesite. you should be able to type in the product you purchased,then a list of options should come up one being the instruction manual which is downloadable or read from screen.
9/13/2009 5:51:08 PM • Evenflo... • Answered on Sep 13, 2009
Transferring piece from one stage to next
There is small buttons on each leg that you nedd to push in and lift the saucer up.
6/23/2009 11:11:12 PM • Evenflo... • Answered on Jun 23, 2009
I need to know how to put the seat in an Evenflo
https://plweb.evenflo.com/faq_detail.aspx?faqid=3934
Question: How do I put the seat pad on the Exersaucer? spacer.gif Answer: 1.Line up the red diamond on the seat pad warning label with the triangle on the back of the seat ring. 2.Fit the elastic loops through the quarter inch gap between the seat ring and rotating rings and hook the elastic loops over the prongs on the bottom of the rotating ring. 3.The plastic tabs on the seat pad are only for reinforcement and don't hook to anything, but should be threaded between the 2 plastic rings. If you still need further assistance please refer to the instruction sheet or call the Evenflo ParentLink Consumer Resource Center at (800) 233-5921 or (937)773-3971 for further information.
4/25/2009 1:48:28 AM • Evenflo... • Answered on Apr 25, 2009
I have a older exersaucer made by evenflo and i dont know how to put the seat back on
original instructions for any exersaucer
https://plweb.evenflo.com/ShowDocument.aspx?ManualID=234
25702569.pdf
3/11/2009 2:53:37 AM • Evenflo... • Answered on Mar 11, 2009
Lost instructions to the evenflo triple fun excersaucer
put the bottom and top togather where the 3 holes are on top put the springs put the caps on and turn them. You will have to use a little pressure but they will turn
3/1/2009 11:11:05 PM • Evenflo... • Answered on Mar 01, 2009
2answers
3 in 1 Exersaucer Pond Stage 3
Go to www.evenflo.com. Click on your product at the top and then on the right side there is a "related link" for product instructions. You will need your Model # and Manufacture date (which is on the seat of the Exersaucer). Then it will list all the parts available for that product. Almost all the way down is a pdf version of the instructions that you can download for free. I used it and was able to assemble my Exersaucer to the 3rd stage. Good Luck!
2/27/2009 12:27:24 AM • Evenflo... • Answered on Feb 27, 2009
Need replacement part,a spring for Evenflo Exersaucer Mega Activi
Check thier website. You can enter in the model # and date of production (seat ring that the cloth attaches to). From there it'll show you all the available parts for purchase. You can also find/buy replacement or "switch a roo" toys from their website. I found this by googling "replacement parts for evenflo excersaucer".
I hope this helps!!!
2/24/2009 9:58:07 PM • Evenflo... • Answered on Feb 24, 2009
How do you fold the Exersaucer Smart Steps?
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
To unfold, simply press on the holding latches, and pull up
2/23/2009 5:02:10 AM • Evenflo... • Answered on Feb 23, 2009
2answers
Need directions on how to fold legs
Hi, I can fix this.
First, on the bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
To unfold, simply press on the holding latches, and pull up.
Good Luck.
Gordon & Shirley
2/3/2009 6:44:11 PM • Evenflo... • Answered on Feb 03, 2009
Evenflo ExerSaucer SmartSteps ABC Stroller Logo
Popular Tags
46 questions posted
Top Evenflo Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
john h
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Evenflo Baby Gear
  • Evenflo Baby Gear
Most Popular Question
locate battery in evenflo mega
  • Baby Gear
