20 Most Recent General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator Questions & Answers
0answers
Water dispenser isn't working and
Easy one. The fridge computer has crashed. Remove and reapply electricity to fridge (via the circuit breaker).
12/15/2012 9:03:38 PM • General Electric... • Answered on Dec 15, 2012
Ice machine overflows with ice
Here is the service manual for the ice maker.
12/4/2012 7:41:17 PM • General Electric... • Answered on Dec 04, 2012
Ice maker not filling
You will need to replace the water inlet valve. Here is the valve to order.
12/4/2012 6:28:32 PM • General Electric... • Answered on Dec 04, 2012
Pgcs1pjx light does not work
well you have an LED light assembly, what this translate to is it may the light fixture, but unlikely. most likely is a computer board on the back of the fridge. I would call for service for them to trouble shoot to insure you get the right part the first time. both parts are a bit pricey.
4/9/2012 3:40:08 AM • General Electric... • Answered on Apr 09, 2012
The light in our refrigerator does not work, we
the operating switch that turns the light on when you open the door may be the problem>
2/13/2011 2:18:34 PM • General Electric... • Answered on Feb 13, 2011
Freezer not cold
have you check the fan inside the freezer? see if it is running.
see also the fridge if it is cooling, if both side are not then there something to do with your compressor, it's either under charge(leak is the cause) or lost compression (mechnical failure inside your motor compressor)
11/6/2009 12:27:24 AM • General Electric... • Answered on Nov 06, 2009
Looking for seal for a General Freezer GC12L, seems to be no longer available?
You can use seal material and make your own. Or you can order by size. https://www.google.com/search?q=General+Freezer+GC12L+Gasket ..
10/11/2022 6:31:20 PM • General... • Answered on Oct 11, 2022
3answers
My refrigerator is general cool owned by climatic brand has started to not cooling as it should be, after a month, the freezer started not to freeze as before and gradually frozen food started to melt down. Before a year or so the upper panel between the refrigerator and the freezer started to carry a lot of water while temperature started to increase day by day. Please device what went wrong. Is it sensor. I disconnect the plug on main pcb then checked the resistance of three sensors: refrigerator R1 defrost D, , and F freezer are 1.2 ohm, 9.2 ohm and 9.1 respectively. The fzn capacitor is working Fine I checked it using the multimeter, it can charge and discharge similar to a new capacitor.
Picture doesn't contain enough pixels to enlarge it... The purpose of a refrigeration system is to move heat from the cabinet and dissipate it into free air. When a refrigeration system is working correctly the compressor, some of the pipework and the condenser will become quite warm and hand-hot in some cases - the interior of the cabinet must then become cold unless there is a fault. If the compressor runs and the condenser doesn't become warm, either the compressor is broken or the refrigerant has leaked away. If the condenser is warm but the cabinet isn't cool enough either the compressor isn't running long enough or the defrost panel is being left switched on. If there is a doubt about the compressor control, the thermostat and sensors, etc. It can be temporarily bypassed for the purpose of testing the other refrigeration components and system.
8/21/2020 9:34:14 PM • General... • Answered on Aug 21, 2020
Dispenser refrigerator general electric does not work, the ice maker is working, some one can help me please? thanks!!
sorry it is difficult to help you when you do not post specifically? when u say it does not work? what do u mean? no cold? no freezing, do u hear the compressor come on? a clicking? You may have a bad defrost timer or cold control that went out, a bad defrost terminator etc? see pics FREEZER /FRIDGE NOT COOLING:Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As perur model. Most should atleast show 1200 ohms. Also Check door seals for leakage. Evaporator coils Poorcooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly. Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air. But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer. Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. May also need to check thedefrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Placeur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. THE COMPRESSOR: If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed. To checkur compressor with multi meter: Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing. You wills see 3 prongs coming out of compressor. 1 goes tour start winding, 1 goes tour run winding and the center goes tour ground. Placeur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms. Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total ofur two separate test. 9 ohms, if they matchur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short inur compressor. It should show infinity TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810. The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection Lastly you should also checkur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required. 1-3 TEMPERATURE CONTROL As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge. On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge. If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it. To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it. You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer The air damper, baffle or diffuser is the device that balances the air flow from the evaporator fan housing. This normally is a mechanically controlled baffle or flapper that controls the amount of cold air entering the fresh food compartment. If the baffle is damaged or the linkage to the control knob is damaged, then you may not have enough cold air entering the fresh food compartment resulting in higher than normal temperatures. This baffle or damper will be located where the cold air enters the fresh food compartment. compressor testcompressorwindings-ugmvngpha3jr3hqbyajv0mwz-4-0.jpg cold temp control location-ugmvngpha3jr3hqbyajv0mwz-4-2.jpg thermistor badgoodthermistor-ugmvngpha3jr3hqbyajv0mwz-4-5.png defrost timer location defrost terminator-ugmvngpha3jr3hqbyajv0mwz-4-9.jpg relay capacitor-ugmvngpha3jr3hqbyajv0mwz-4-14.jpg Refrigerator Is Not Cooling What To Check And How To Fix
5/18/2019 7:54:20 PM • General... • Answered on May 18, 2019
Is there a fuse on a general electric refrigerator? if there is where is it located
Some control boards have fuses in them.
10/13/2018 1:01:37 AM • General... • Answered on Oct 13, 2018
Ice buildup at the bottom of freezer
The most common cause of this is a poorly fitting and or damaged fridge door seal. The humidity in the air freezes turns to ice.
7/26/2018 7:14:13 PM • General... • Answered on Jul 26, 2018
General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator Logo
18 questions posted
Top General Refrigerators Experts
vince
Paul Bade
Arnie Burke
Arnie Burke
Are you a General Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • General Refrigerators
Most Popular Question
ice machine overflows ice
  • Refrigerators
