20 Most Recent La Crosse XG-55 Wrist Watch Questions & Answers
Manual doesn't help. I changed the battery but the watch is still not powering up.
La Crosse XG-55... | Answered on Mar 20, 2019
Go through the user Manuel and see the instruction and see how to replace the battery :
No we don't touch with a metal there is no need to do that :
http://www.lacrossetechnology.com/xg55/manual.pdf
If your numbers dim when you push any button, it's probably a battery. If your numbers are off or very faint same problem, battery. Those watches take a 1.50 V cell because of the light, and multi functions. Any decent jewelry store should be able to have you in and out in 10 minutes or sooner.
Good luck, gabe.
La Crosse XG-55... | Answered on Oct 23, 2015
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for
the small cost saving in doing it yourself.
La Crosse XG-55... | Answered on Aug 14, 2010
Try shorting the battery case to the watch chassis (using a pair of tweezers perhaps).
This seems to be a standard instruction and I think this resets the watch.
La Crosse XG-55... | Answered on Apr 24, 2010
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
La Crosse XG-55... | Answered on Nov 19, 2009
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
La Crosse XG-55... | Answered on Apr 04, 2009
La Crosse XG-55 Wrist Watch Logo
19 questions posted
Top La Crosse Watches Experts
Arturs Kalnins
Arturs Kalnins
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
View Most Popular
La Crosse Watches
  • La Crosse Watches
Most Popular Question
when replace battery
  • Watches
