20 Most Recent
Breville BJE510 900 Watts Juicer Questions & Answers
The motor stopped while juicing hard veggies and
There may be an overload switch somewhere on the unit, it will just be a small button projecting from the underside most probably or in a small hole. If there is, just depress it. If the unit actually burned out yu would have seen smoke and smelled it.
How do I remove the
IF THE STAINS ARE ON THE OUTER BODY REMOVE THEM WITH THE NAIL POLISH REMOVER, IT DOES WONDERS.
REGARDS.
PLZ. RATE THIS
Error message
I fixed my juicer that had this problem, the problem was the thermal fuse which is located directly on the motor with some plastic covering it. You can replace the fuse or do what I did and just cut off the fuse and attach the two wires together (no more fuse) and my machine now works again :)
