20 Most Recent Crosley CE35111AA Electric Kitchen Range Questions & Answers
tip
Appliances Houston
We sell NEW overstock and scratch & dent appliances which come directly from Whirlpool. From ovens to refrigerators, microwaves to washers and dryers, stoves and dishwashers-all your home appliance needs for less than EVERYONE ELSE! Solocenter.com
I can't find a button
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps!
9/20/2015 6:53:05 PM • Crosley... • Answered on Sep 20, 2015
My crosley self cleaning oven door is locked and i can't open it
I don't know if this will help, but try unplugging the stove from the back of the electrical outlet to the wall, wait for a minute or so, then plug back in and see if this works. I know with other similar problems of this nature, it has worked. Can't loose without trying. K.E.
5/21/2015 3:46:38 AM • Crosley... • Answered on May 21, 2015
It's flashing F3 and I can't get it to reset.
Hello & Welcome to FixYa
F3 error means a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
2/3/2011 8:11:38 PM • Crosley... • Answered on Feb 03, 2011
2answers
Crosley self cleaning oven manual
I have a crosley but don't know if it is the same model.
Hope that helps! RC
10/17/2010 9:35:32 PM • Crosley... • Answered on Oct 17, 2010
When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
7/26/2010 7:43:16 PM • Crosley... • Answered on Jul 26, 2010
I have a crosley oven that keeps beeping at me and
Your electronic control (clock) is bad. Replace it.
6/11/2009 11:09:18 PM • Crosley... • Answered on Jun 11, 2009
I have a kitchenaid ceramic
is it the glasstop range with the oven control panel in the front? if so one of your over temperature thermostats is faulty.. it is probably causing an f-1 error.OR.. your temperature probe in the oven could be going bad.
1/1/2009 2:55:36 AM • Crosley... • Answered on Jan 01, 2009
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
5/5/2008 10:09:23 PM • Crosley... • Answered on May 05, 2008
Crosley stove door isn't locked but when I push bake says unlock door
You can try this..turn the circut breaker off for a couple of minutes to see if it resets.
12/23/2022 5:27:20 PM • Crosley Kitchen... • Answered on Dec 23, 2022
Why doesn't it turn on when I hit the brake?
I think you need you to find a technician for that fix.https://chicagotuckpointingandmasonry.com
3/22/2021 2:44:59 PM • Crosley Kitchen... • Answered on Mar 22, 2021
I have a Crosley gas oven model CG31200BDW the stove turns on and is working fine, however the oven will not heat up. Please help?
This model number does not show valid, please double check. In general, if the surface burners work, then suspect a bad oven ignitor. Does the ignitor glow? If so, and the burner doesn't come on within 30 seconds, replace the ignitor, it's weak and not passing enough power to open the gas valve. If the ignitor does not glow then you must check the ignitor for continuity (replace if open/no circuit) and back check the circuit for lost power. If not the ignitor then suspect a bad relay on the control board.
11/8/2020 2:21:16 PM • Crosley Kitchen... • Answered on Nov 08, 2020
F5 code on crosley model ce3878vvv stove oven wont work or broiler
Most Frequent Causes for F5 - A "watchdog" circuit on the clock assembly control board is sensing a hardware problem
11/10/2018 5:52:29 AM • Crosley Kitchen... • Answered on Nov 10, 2018
Get a f-5 code on my crosley m#ce3878vvv stove when I try to use oven turn breaker off and on still does same code broiler does same code burners work fine
Replace clock assembly
https://www.repairclinic.com/RepairHelp/FaultCodes/10/Range-Stove-Oven
11/1/2018 5:52:31 PM • Crosley Kitchen... • Answered on Nov 01, 2018
I have a Crosley oven and I'm getting a beeping sounds and error message F31 and I cannot find my manual How can I fix it?
I had the same thing going on literally just now. I unplugged it, plugged it back in, and now it is working fine. O.o
10/7/2018 6:05:13 PM • Crosley Kitchen... • Answered on Oct 07, 2018
Crosley CE35111AA Electric Kitchen Range Logo
28 questions posted
Top Crosley Kitchen Ranges Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Kitchen Ranges
Most Popular Question
crosley self cleaning oven manual
  • Kitchen Ranges
