20 Most Recent
Bunn -o-Matic G3 (3 lb. Commercial Coffee Grinder) Questions & Answers
No power bunn-o-matic
Look on the right side of the grinder, there is little cover. Pop the cover off and press the reset button.
I cannot adjust the grinds its only cming out fine even if I turn the screw in the center
You should call your vendor for service.
*** The following is for information only. Service should be done by a qualified tech.***
* Check bunn.com for a free download of the G3 manual
* If turning the dial does not change the grind size then the inner burr spring is broken, stuck, of missing (it broke into small pieces to fall into someone's coffee grounds). Call vendor for service.
* If turning dial is very loose then the lock screw is loose. check setting then tighten down to lock into place. It's usually a small 1/4" hole on the side of the knob.
* The burr plate may be gummed up and stuck in place. Especially if oily beans or 'flavored' beans were ground in this machine often.
* It's possible the Grinder is WAY out of calibration. It's so far out of adjustment that the only setting is fine when the dial is set on course ground. This grinder was not assemble correctly. Check the parts diagram. Call your vendor for service.
Aloha, ukeboy57
Bunn G9 ground coffee is spraying outwards instead of down. How do I fix this?
Bunn G9 Retail grinder usually has a large "Chaff" plate located inside the top portion of the discharge port. There is usually a handle connected to this plate to allow the last bit of grounds to fall out of the chute. It looks like a 'trap door' that swings open and close. You will need to replace it if it's missing.
* Some places use a bag clip to attach a coffee bag to the chute so all the grounds can drop into the bag. This clip (with a small metal chain attached) also helps with the static electricity.
Aloha, ukeboy57
How to calibrate my Bunn grinder.
It would be easier to pick up the manual in the commercial section under products from bunn.com, rather than me explaining it.
You have to loosen the nut on the adjustment wheel, then pull out slightly and turn towards coarse a few numbers, then push back in and turn grinder on and slowly turn toward fine, until the burrs slightly touch, you will hear a little metal on metal, at that point turn the grinder off, back off about slightly, then pull out adjuster and turn it to Turkish and tighten screw.
It always grinds very fine. I am unable to change
That one is hard to explain but I will try. On the front of the grinder is the adjustment wheel, on the wheel is a small screw, if you put your hand on the wheel it might be about 1/4 inch from the front, back up screw about 1/2 turn or more then make sure the grinder is on 3 or espresso, make sure you can pull out front part of the wheel ONLY. If not back up screw a little more and try again, now that it can move freely without moving the numbers, pull it out and turn it to about 5 or 6 then turn grinder on and very SLOWLY, (This is the dangerous part do not go to fast or you could damage the grinder) turn towards trukish grind when you get close you will hear the burrs slightly touching. Back off the knob a little just before the touching part and turn grinder off. Then pull knob out and turn it to turkish and set screw.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
