20 Most Recent Bunn CWTF 35-APS Coffee Maker Questions & Answers
Wiring
jumper the red and white wires at the terminal block
1/28/2015 4:21:52 AM • Bunn CWTF 35-APS... • Answered on Jan 28, 2015
Have a Bunn CWTF, when the switch is pushed and water begins to flow thru the basket, there is a small amount of water that begins to puddle on top of the left tank (right does it also, but less).
Leaking from top of tank; Call for service as this is an electrical hazard. *** the following is for information only. *** * Replace any worn gaskets and silicone tubes. * There may be cracks in the metal pipes. Hard to see, but there, if you remove the lime deposits. * check the top tray nut if the gasket to the tank is missing. It's about an 1-1/4" round washer with about a 3/4" hole. Usually made of white silicone rubber. It seals the fill tray to the tank. Leaks often. * Bunn equipment can last quite a few years (decades?) but the gaskets do get hard and the tank needs to be water tight to work properly. Since this is already an old brewer and you've saved money rebuilding it. Suggest going further by replacing all gaskets. Yes they do need to be snug with no cracks. Aloha, ukeboy57
1/20/2018 8:24:54 AM • Bunn CWTF Coffee... • Answered on Jan 20, 2018
Water keeps running out of shower head of my bunn cw series coffee brewer
see callibration tip for bunn cwtf
1/28/2015 4:25:45 AM • Bunn CWTF Coffee... • Answered on Jan 28, 2015
How to descale Bunn CW15-APS coffee maker
delime the sprayhead and reservoir drain (in the top) with a deliming spring or a screwdriver. to delime the tank, put a half gallon of vinegar in the top and catch the hot water as it comes out of the sprayhead. leave it sit for about 20 minutes and brew at least 8 times (w/o coffee) or until you can no longer taste vinegar
1/28/2015 4:25:18 AM • Bunn CWTF Coffee... • Answered on Jan 28, 2015
Warming plate and light stopped working on Bunn coffee maker
replace the switch
1/28/2015 4:20:47 AM • Bunn CWTF Coffee... • Answered on Jan 28, 2015
Bunn water level
What about Bunn water level? Too high? Too low? Not filling? Leaking?
11/25/2014 9:21:13 PM • Bunn CWTF Coffee... • Answered on Nov 25, 2014
I have an Bunn model GRX-B datecode 304009 that leaks at the bottom, what can be done about it
Most likely cause is that the seal between the water reservoir and the tank is leaking. Not uncommon. If you can find a replacement seal go for it, otherwise the old one can be made serviceable by coating both sides with a thin bead or layer of clear silicone. Allow to cure for 24 hours before powering the coffee maker back up.
11/23/2014 8:10:01 PM • Bunn CWTF Coffee... • Answered on Nov 23, 2014
How can I tell if maker is wired for 220 or 120
If its been changed to 220V plugging it into 120V won't damage anything, it just won't work. Replace the plug with a 120V plug end and plug it in. If it works its120 if it doesn't, its either a 220V setup, or you have a blown fuse in the unit/power supply or some other defect.
11/5/2014 8:04:36 AM • Bunn CWTF Coffee... • Answered on Nov 05, 2014
I have two older style used Bunn CWTF coffee makers. Both if them have the same issue. When the unit is not even plugged in or turned on, and the water source is turned on, water shoots from the fill
the plunger for ur solenoid valve assembly might be stuck in open position ... ur click sound maybe came from ur funnel lock during brewing. water shots from the fill or oveflow cup due to contoniuos supply of water , try to close ur main water and c if water will also cease
10/2/2014 3:09:32 PM • Bunn CWTF Coffee... • Answered on Oct 02, 2014
Bunn CSB3T Speed Brew Platinum Thermal Coffee Maker, 10-Cup. It seems to not brew as hot as when we first got it.
Somewhere inside you should find a small rotary thermostat. Also make sure the heating element is completely clean by using a quality descaler like CLR. A lot of people use white vinegar but it is not that effective on coffee makers. Make sure the heating element under the carafe is working, because that is heating up as the coffee is brewing. ..
2/13/2024 6:14:34 PM • Bunn Coffee... • Answered on Feb 13, 2024
Bunn-o-Matic HB coffee maker. How do you read the date code on it please?
Question edited for clarity and toss in a load of CAPS. It is dated with a non intuitive, none readable code. You can see examples here. Where is my Date Code? BACK OF BREWER Sticker on the lower back of brewer BOTTOM OF BREWER Sticker attached to the bottom baseplate of your brewer. Note: Allow water in tank to cool. Drain water before turning over.
Where is my Date Code? - BUNN
More here https://www.google.com/search?q=Bunn-o-Matic+HB+coffee+maker+read+the+date+code ..
12/13/2023 2:02:06 AM • Bunn Coffee... • Answered on Dec 13, 2023
Someone put coffee grounds in my BUNN VPR BLK water revisor. How do I clean it out?
unplug machine and turn upside down and pour out coffee and water mix (if water was in reservoir) If necessary turn over and fill will water and repeat.
11/21/2023 6:08:41 PM • Bunn Coffee... • Answered on Nov 21, 2023
When cleaning the Bunn, when to replace the sprayhead after deliming.
Replace and run a pot of clean water thru it.
7/21/2023 8:52:20 PM • Bunn Coffee... • Answered on Jul 21, 2023
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
  1. Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
  2. Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
  3. Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
7/2/2023 2:45:35 PM • Bunn Coffee... • Answered on Jul 02, 2023
Bunn Coffee maker Model CWTF-15 Water is continuing to flow after pot is made. The machine must be turned off to get it to stop.
Normally that would be an easy fix if the water just continued to flow. You just replace the water inlet valve and they can stick open or partially open. But you say if you power off, the flow stops. That sounds like the control board is supplying residual power to it. Control boards are expensive so I would call for service. Or you can try some of the fixes here. https://www.google.com/search?q=bunn+coffee+maker+cwtf15+replacement+water+inlet+valve More here https://www.google.com/search?q=bunn+coffee+maker+cwtf15+water+not+shutting+off ..
5/17/2022 4:56:40 PM • Bunn Coffee... • Answered on May 17, 2022
Why does the Bunn CWTF we have trip the circuit breaker when it gets plugged in?
shorted water heater element
3/27/2022 5:34:54 AM • Bunn Coffee... • Answered on Mar 27, 2022
Need temperature limit switch for garbage Bunn coffee maker.
Not sure your model name is correct and we always need numerical model names here. Bunn are such a well known name in coffee machines, I find it disappointing that they say ANY machine is not repairable. I found some Training Manuals and I found a 'Thermostat Limit Kit'. https://www.google.com/search?q=bunn+grab+fast+brew++temperature+limit+switch The search query would be Bunn (numerical model number) temperature limit switch ..
2/19/2022 5:25:08 PM • Bunn Coffee... • Answered on Feb 19, 2022
Bunn CWTF 35-APS Coffee Maker Logo
Popular Tags
1 questions posted
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
CWTF Bunn
  • CWTF Bunn
Most Popular Question
wiring
  • Coffee Makers & Espresso Machines
