20 Most Recent
Bunn VP17-2 Coffee Maker Questions & Answers
How can I clean my bunn vp17-2 coffe maker the
First make sure you have enough water in the machine. It holds about 2 and a half pots of water in the holding tank. If the machine sits for a week without use but is still plugged in, sometimes the water will evaporate down to the point where pouring one pot of water in, will not fill the tank back up. If you still don't get a water flow, take the brew funnel out and reach up where the water normally comes out, There is a round water dispenser about 2 inches in diameter. Unscrew it by turning countercloclwise. It has a dozen or so holes where the water come out. Be sure these holes are not stopped up. There is a small pipe fitting where you took the water dispenser off. Bunn makes a long spring like thing that fits into this hole to remove built up lime deposits. If you don't have one you can use a flexable wire like braided copper wire about 18 inches long to push through the hole and slide it back and forth until it comes out clean. If you have hard water, like well water you may be getting a lot of calcium build up in the tank. Put about a quart of vinegar in the next coffee pot and let it sit an hour. Pour water through the machine until it stops smelling like vinegar. That should solve your problems.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
