20 Most Recent
Bunn CDBCF 15 APS Coffee Maker Questions & Answers
Water Level Has Dropped
you may need to reset the dispense time. open the front panel and read the instruction on the panel itself. make sure the switch is in the "lock" position when you are done.
Working properly but hot water not being produced
the thermofuse is shot. you will need to replace it. open up the top of the brewer and you will see a burnt piece of tubing with wires coming out both sides on the right rear of the top. one end goes tothe front and the other to the heater.
Only brews a half pot
you may need to reset the dispense time. open the front panel and read the instruction on the panel itself. make sure the switch is in the "lock" position when you are done. also try deliming the machine. loose lime pieces will restrict the flow.
Coffee maker continues hot water flow even after
definitely clean out the sprayhead. also, you may need to reset the dispense time on the board behind the front panel. the instructions are on the panel itself. make sure the switch is on "lock" after you are done.
How to reset a digital water level for the coffee
Turn front panel on/off switch on then hold brew button in continuosly until 3 clicks are heard,then release.Brew timer is then stated.When desired level is reached turn on/off switch off to set.
Will not get hot
Bad heating element,hi-limit or main control board behind front panel is bad.
The coffe pot will not produce full pot of coffee
Check programming.This is very simple;turn switch on and hold brew switch until you here 3 clicks to start brew timer .When desired level is reached turn off on/off switch on front panel to set brew time.Check brew level now.
Faema due smart two group espresso machine, I am
when you open the hot water valve all the way does the pump come one? You might have a newer version that has a mix valve. This allows a controlled amount of cold water to be mixed in with the boiling water from the boiler. If so you would find an adjustment (usually just a black knob) that is next to that valve. If the final amount of water for the espresso is fluctuating then you have a problem with your flow meters (dirty impellors or bad field sensors). If you notice a different in the amount of water flowing from one group to the next then something is clogging up the jets or group heads. It could also be a sign of your dispersion screens going bad or other stuff. Have you had it maintenance within the last six months. I have the manual for that machine if you need a copy.
Good Luck,
[email protected]
Cleaning
To clean the pump pot, use purocaff, add a teaspoon of the soap to the pump pot then fill with warm water, let sit for about 1 hour, then use a brush to clean.
Stopped making hot enough water
Hello. If the temp is coming out low, there are a few possibilities. You said the "green" light was lit, is this a ready to brew lamp? if so, your thermostat is indicating it is at temp, even though it is not. I would say that it has failed, and needs replacement. It could be it has overheated, and tripped the safety limit, the heater has failed, a wire burnt off, it would require checking with a multimeter to know for sure. Take it to, or call a servicer, and have it checked, if its commercial, you can find a servicer in the phone book, under "restaurant equipment repair".
Hope that helps, and thank you.
Coffee maker
1- YOU MUST TO DESCALING THE MACHIN BY USING ITS SUITABLE AGENT ONLY. THANK YOU
