20 Most Recent
Bunn CW 15-APS Coffee Maker Questions & Answers
There is no voltage (120V) to the tank heater.
The thermal fuse is a little silver looking thing. It is normally mounted near the heating element. They are normally rated just above boiling, 105 C. The only time I have ever seen them open is when the thermostat is beginning to fail and stick on causing the temperature to exceed the boiling point.
Post a link to the online manual and I will see if I can find the thermal fuse.
Good luck, Jim
PS: I do not recommend by passing the thermal fuse. I did this on a coffee maker I had and the next time the thermostat stuck, the thing caught fire :O
I filled the reservoir and
This is a pour over brewer if it does not have a brew switch, you have to pour water into the top to brew the coffee.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
