20 Most Recent Bunn VP17-1 Coffee Maker Questions & Answers
2answers
Do you have to unplug coffee maker when not in use?
You dont have to unplug unit but you can if you like. Most people leave them plugged in. This keeps water hot and on the ready when you need coffee. When the unit is unplugged there is a waiting time before the water comes to temp. If your unit will not be used for weeks at a time, I would unplugged it, but if used regularly I would leave it plugged in.
7/22/2014 11:11:43 PM • Bunn VP17-1... • Answered on Jul 22, 2014
Why does it drip really slow?
Perhaps you need to get rid of the calcium hardness? Did you try putting vinegar in the water container, and after switching it on for a little while, switching it off and leave it for an hour or so. Then repeat this and when the water goes better, twice ore three times plain water. to clean the machine form the vinegar. There are also special sachets with a likely acid you can use.
6/3/2014 3:52:52 PM • Bunn VP17-1... • Answered on Jun 03, 2014
2answers
No pot or instructions, how
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
4/26/2014 11:27:48 AM • Bunn VP17-1... • Answered on Apr 26, 2014
Bunn CSB3T Speed Brew Platinum Thermal Coffee Maker, 10-Cup. It seems to not brew as hot as when we first got it.
Somewhere inside you should find a small rotary thermostat. Also make sure the heating element is completely clean by using a quality descaler like CLR. A lot of people use white vinegar but it is not that effective on coffee makers. Make sure the heating element under the carafe is working, because that is heating up as the coffee is brewing. ..
2/13/2024 6:14:34 PM • Bunn Coffee... • Answered on Feb 13, 2024
Bunn-o-Matic HB coffee maker. How do you read the date code on it please?
Question edited for clarity and toss in a load of CAPS. It is dated with a non intuitive, none readable code. You can see examples here. Where is my Date Code? BACK OF BREWER Sticker on the lower back of brewer BOTTOM OF BREWER Sticker attached to the bottom baseplate of your brewer. Note: Allow water in tank to cool. Drain water before turning over.
Where is my Date Code? - BUNN
More here https://www.google.com/search?q=Bunn-o-Matic+HB+coffee+maker+read+the+date+code ..
12/13/2023 2:02:06 AM • Bunn Coffee... • Answered on Dec 13, 2023
Someone put coffee grounds in my BUNN VPR BLK water revisor. How do I clean it out?
unplug machine and turn upside down and pour out coffee and water mix (if water was in reservoir) If necessary turn over and fill will water and repeat.
11/21/2023 6:08:41 PM • Bunn Coffee... • Answered on Nov 21, 2023
When cleaning the Bunn, when to replace the sprayhead after deliming.
Replace and run a pot of clean water thru it.
7/21/2023 8:52:20 PM • Bunn Coffee... • Answered on Jul 21, 2023
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
  1. Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
  2. Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
  3. Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
7/2/2023 2:45:35 PM • Bunn Coffee... • Answered on Jul 02, 2023
Bunn Coffee maker Model CWTF-15 Water is continuing to flow after pot is made. The machine must be turned off to get it to stop.
Normally that would be an easy fix if the water just continued to flow. You just replace the water inlet valve and they can stick open or partially open. But you say if you power off, the flow stops. That sounds like the control board is supplying residual power to it. Control boards are expensive so I would call for service. Or you can try some of the fixes here. https://www.google.com/search?q=bunn+coffee+maker+cwtf15+replacement+water+inlet+valve More here https://www.google.com/search?q=bunn+coffee+maker+cwtf15+water+not+shutting+off ..
5/17/2022 4:56:40 PM • Bunn Coffee... • Answered on May 17, 2022
Why does the Bunn CWTF we have trip the circuit breaker when it gets plugged in?
shorted water heater element
3/27/2022 5:34:54 AM • Bunn Coffee... • Answered on Mar 27, 2022
Need temperature limit switch for garbage Bunn coffee maker.
Not sure your model name is correct and we always need numerical model names here. Bunn are such a well known name in coffee machines, I find it disappointing that they say ANY machine is not repairable. I found some Training Manuals and I found a 'Thermostat Limit Kit'. https://www.google.com/search?q=bunn+grab+fast+brew++temperature+limit+switch The search query would be Bunn (numerical model number) temperature limit switch ..
2/19/2022 5:25:08 PM • Bunn Coffee... • Answered on Feb 19, 2022
Thanks for those replies! Model is grxb, code 201616. Temp switch has part numbers on it. Any ideas on outside vendors? Thanks
Question edited for clarity. Question moved from Refrigerators. Hi again Bill Making a new post as a follow-up doesn't work here at Fixya. Posts are not threaded or linked, so this post has no context to your previous post. What you wrote here should be in the older post as a reply to Brett and I. You just click COMMENT under our answers to you. The benefits are that it keeps everything together and we get a notification that you require further help. And apparently is is a 'Bunn GRX-B Coffee Maker'. Capitalization and dashes are important to the search :>) https://www.fixya.com/support/t29863408-need_temp_limit_switch_garbage_bunn ..
2/19/2022 5:13:19 PM • Bunn Coffee... • Answered on Feb 19, 2022
Bunn coffe marker not holding water
i think you may have to get a new one
2/2/2022 4:00:57 PM • Bunn Coffee... • Answered on Feb 02, 2022
I'd like to replace the warmer switch on my Bunn coffee maker. The model # is BX-B. Where can I buy one?
only from BUNN AND POSSIBLYTHRU A DEALER
12/12/2021 2:13:22 PM • Bunn Coffee... • Answered on Dec 12, 2021
2answers
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
11/12/2021 10:19:29 PM • Bunn Coffee... • Answered on Nov 12, 2021
I have a Bunn stf-15 coffeee maker that has started to overflow the top tank, what can cause this.?
Hell and good day, this simply means that it need to be service Thanks for coming.
6/29/2021 2:16:43 PM • Bunn Coffee... • Answered on Jun 29, 2021
2answers
Bunn coffee maker heats but wont pump water?
I thought these are pour over brewers? Which means you have to fill it with water in order to brew? It should happen when the unit is filled first, plugged in then turned on.(see link below for MFR instructions) Aloha! ukeboy57 http://www.bunn.com/sites/default/files/care-and-cleaning/43097_0002d01_velocity_brew_manual_english-_bt_st.pdf
6/9/2021 12:37:08 AM • Bunn Coffee... • Answered on Jun 09, 2021
Bunn VP17-1 Coffee Maker Logo
Popular Tags
5 questions posted
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Bunn Coffee Makers & Espresso...
  • Bunn Coffee Makers & Espresso...
Most Popular Question
  • Coffee Makers & Espresso Machines
