20 Most Recent
Dirt Devil CE7000 Easy Steamer Upright Wet/Dry Vacuum Questions & Answers
Easy steam express ll not steaming
The problem with the DD steam mop is not getting steam out but trying to get it to keep coming out. If U disassemble the plastic housing around the handle U will see a small part connected to 2 hoses, one going to the water reservoir the other going to the heating unit. This is the pump which provides water to the heating unit, and if this fails U won't get steam. U can try disassembling this and try to get the piston to move more freely. A loud clicking sound coming from this should indicate good movement and a feeble click click click may indicate restricted movement.
Hope this helps
How do i unclog?
take all hoses off bottom to the spindle check for obstructions clean filters or bag
What is the filter bag number
type G
look on amazon or copy and paste
https://www.amazon.com/dirt-devil-model-103-bags/s?k=dirt+devil+model+103+bags
Dirt devil power stick lite edge to edge
See picture for details. It is unnecessary to remove the roller brush to clean it. The picture will show you how to do but not all vacuum cleaners will have a line where to cut. In this case, you can still use a utility knife just be more cautious where your cutting and not too deep. Make your cuts on both sides of the roller.
If you still need to pullout the roller brush, don’t worry too much about pulling it out strait. Pull one end slightly, do the other end in the same way until it comes out.
