20 Most Recent Magic Mill DLX 2000 Stand Mixer Questions & Answers
My kitchen aid mixer model k45 will only operate
Hi REINO66, I suspect you (speed) Control Plate Assembly has gone bad and needs to be replaced.
The good news is that this can be fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, feel adventurous, and your mixer is not under warranty. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Find Illus. No. 25, Control Plate Assembly, Part No. 240904-2, which is the part that needs to be replaced.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able replace your Control Plate Assembly.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
12/15/2018 8:38:39 AM • Magic Mill DLX... • Answered on Dec 15, 2018
Magic mill mixer
majicmill.com
You may be having a problem with the motor brushes and/or bearings.
1/16/2014 12:24:19 AM • Magic Mill DLX... • Answered on Jan 16, 2014
Where can I download a
3/29/2013 11:14:37 PM • Magic Mill DLX... • Answered on Mar 29, 2013
0answers
Where can I download manual for the Magic Mill
The manual is $10 from the manufacturer, you can order from the following link.
http://magicmillusa.com/index.php?event=product-detail&productid=51
Let me know if you need anything else.
Benjamin
11/4/2010 6:13:43 PM • Magic Mill DLX... • Answered on Nov 04, 2010
2answers
Pin that secures roller is stuck in the down
What is the make and model of your mixer?
If there is a possibility that some food could have dripped onto the pin, it could be creating problems with the mechanism. If you are able to remove the bowl, try the tipping the arm into a bowl of hot water in hopes of loosening up any food debris in the mechanism. Power cord disconnected of course. :-)
It is possible that there is a spring inside the mechanism that has failed. If this is the case, it will need to be disassembled for repair.
I look forward to hearing back from you regarding the make and model of your unit. :-)
4/12/2010 12:13:12 AM • Magic Mill DLX... • Answered on Apr 12, 2010
2answers
Instruction manual for magic mill 2000
http://magicmillusa.com/items.php?category=26
9/28/2009 8:14:57 PM • Magic Mill DLX... • Answered on Sep 28, 2009
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
4/17/2009 2:58:18 AM • Magic Mill DLX... • Answered on Apr 17, 2009
Noise level
its possible that you got a lemon off the factory line or they forgot to put grease into the transmission case.is there a warranty on it?if so take it back.i work for hobart which sold kitchen aid some years ago,if that mixer is less than a year old as stated,take it back or verbally speak to a kitchen aid rep. and tell them your situation.i really belive you should be able to get a replacement as long as you havent overloaded the unit or caused damage.let me know.
1/4/2008 11:50:11 PM • Magic Mill DLX... • Answered on Jan 04, 2008
Magic mill DLX 2000 base sent to repair place
I just found my old invoice where I had sent my DLX to be repaired a few years ago. (I had not put in enough moisture and it walked off the (rickety) table I had set it on...)
I need to send it back again and hence my search for the info.
The gentleman I sent it to was Mordechai Roth at Magic Mill Corp in Monsey, NY (10952) This occurred back in 2000, I can't believe I saved the receipt...
Phone number is 914-368-2532 (If it's still good) I am calling tomorrow to see about sending mine in... Hope you find yours...
JT
1/3/2008 6:58:12 AM • Magic Mill DLX... • Answered on Jan 03, 2008
How to change the belt in a Bodum electric mixer?
Question moved from Cars and Trucks. Stand Mixers don't normally have belts and I don't believe this one does as I can't find spare belts. They are operated by nylon cogs that run in grease. The most likely reason is the she shear pin has sheared. This is a small pin like a nail that goes through a cog or shaft and shears if too much load is put on the mixer beater or dough hook. It often happens if you make bread and have the speed too high. https://www.google.com/search?q=change+the+belt+in+a+Bodum+electric+mixer ..
3/5/2024 12:47:57 AM • Food Mixers • Answered on Mar 05, 2024
Harbinger LP9800 mixer keeps shorting out, what can we do? Its been happening for a few months.
You will need to get a qualified electronics technician to look at it. The issue could be anywhere on the circuit boards inside the mixer. Unless you know what you are doing don't try to repair it yourself as you could make the problem worse.
2/29/2024 4:34:11 PM • Food Mixers • Answered on Feb 29, 2024
Magic Mill DLX 2000 Stand Mixer Logo
Popular Tags
24 questions posted
Top Magic Mill Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Magic Mill Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Mill Food Mixers
Most Popular Question
  • Food Mixers
